acceleration question
Discussion in 'Gen 3 Prius Technical Discussion' started by joeb24, Feb 1, 2010.
  1. joeb24
    joeb24 Junior Member
    Alexandria, VA
    When accelerating moderately from a dead stop, I feel a little shuttering for about a second, and then smooth acceleration. When I press on the pedal gently from a dead stop, I do not get this brief shuttering. I am assuming the shuttering when accelerating modrately is the result of the ICE kicking in suddenly? Any thoughts?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Correct. At slower acceleration you are running only on MG2 with MG1 spinning backward to keep the ICE stationary. When the ICE needs to start, MG1 has to rapidly change speed to spin the ICE up to starting speed.
    On a brisk start, the Prius immediately fires off the ICE.
    Tom
  3. joeb24
    Alexandria, VA
    Thanks very much. So, apparently, if the Prius needs to fire up the ICE on a brisk start, this is not an entirely smooth, transparent process.
  4. qbee42
    18,058
    3,076
    Northern Michigan
    It's fairly smooth. Think about starting the engine in a normal car, then consider what it takes to do it on the fly. That said, I can always tell when the ICE starts and stops on my Gen II Prius.
    Tom
  5. bwilson4web
    15,932
    It is not as 'smooth' as electric power.
    Do you notice it all the time or it is occasional?
    How long have you had the car?
  6. joeb24
    Alexandria, VA
    I have had the car about 11/2 months. I drive in ECO mode most of the time. It only happens when I try to accelerate briskly. When I am gentle on the pedal, it accelerates smoothly, but, of course, more slowly.
  7. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    I suspect it will smooth out as the car gets some miles on it. My GII is very smooth at it now. Not so when new.
  8. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    mine does the same thing. I don't think it will get any better as mine has not in over 13,000 miles. But it's not a big deal and i know why it happens. I just think it feels just like a normal car shifting from first to second gear.
