Accelerator Pedal
Discussion in 'Gen 3 Prius Technical Discussion' started by Susan4ET, Mar 2, 2010.
  1. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Is it normal (every car) for the accelerator pedal to bottom-out on the floor carpet? (Not moving & systems 'off')
  2. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    No
  3. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    Only if you have your foot on it.
    50,804
    or under it.;)
  5. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Okay wise guys...
    I talked about the accelerator pedal with the service manager at my dealer. We noted that the bottom of the pedal actually has a protrusion to it and that the design is for the pedal to be able to move all the way into the floor carpet as normal. He pointed out that flooring the pedal this way while driving results in no additonal speed out of the car past the normal max acceleration point. Unfortuately I also talked to Toyota Customer Support (the 800 number) and after leaving me on hold for a few minutes they came back to say that the pedal should never be able to travel down to the floor.
    So here we are with another very trivial difference between who you talk to at Toyota. Very disappointing for an anal Prius owner/driver who never thought to note this on her now traded in 2007 Prius.
  6. vegasjetskier
    269
    29
    I'm confused about what you're trying to get at. What is your question, exactly?
  7. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Well darn... Car is parked. I open the door and crawl up to the accelerator pedal and with a free hand push the pedal down all the way to the floor carpet. The pedal itself apparently has no internal stop but relies on the pedal travel bottoming into the floor carpet. The pedal has a littl protrusion that is what hits the floor carpet appearing to be the design. Is this normal? Several now say no. One service manager says yes its normal. Got it? The question has _nothing_ to do with actually how you drive the car. It is a static question.
  8. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    That's the way mine works and why is this a problem for you?:confused:
  9. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Since the pedal shaft and housing are made of plastic, be
    *thankful* that the floor stops it where the force of the foot
    would be on it rather than all that going through the lever arm
    of the pedal stick which would probably break it at the pivot.
    That probably *is* by design, given the nub on the backside of
    the pedal piece which would otherwise serve no purpose.
    _H*
  10. vegasjetskier
    269
    29
    I can't tell you for sure that it's normal, but logically it makes sense to me that it would be. If it's not allowed to go all the way to the floor, the pedal would have to have an internal stop mechanism capable of resisting the full pressure that a human leg could apply to it. The mount would have to be equally as strong. This would necessitate more and/or stronger material in those areas. Why do that when you can just use the floor as the stop?
  11. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    I agree. The brake pedal does have a limit and it is constructed much tougher. What bothered me at first glance was that the accelerator pedal had no internal stop, but I like your reasoning as to why not. Maybe I thought there would be a little wear pad on the carpet too. But who normally ever pushes their accelerator down to the floor?
    However, lastly, why does Toyota Customer Service get it wrong too. Is it possible that the phone people there talk to other people who really don't know? Well, they gave me a reference number but I don't think they give a rats nice person what I do with it.
  12. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    If the accelerator pedal cannot touch the floor, there won't be "flooring the accelerator", right?
  13. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    True, and have you heard of someone "putting the accelerator through the floor" before?:eek:
  14. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    In my experience the people paid to answer the phone at Toyota Customer Support don't know much. The dimbo I spoke with didn't know the length of the Prius warranty in NJ and hung up on me. This is Toyota's version of "The Helpless Desk". Every corporation has one, sad to say. On a technical question if it is a choice between believing a mechanic or CS I'd believe the mechanic. If it is a choice between believing a mechanic & the PC consensus I'd believe PC.
  15. leeb18c
    272
    202
    SF Bay Area
    That reminds me of my dad's old pickup truck back in tropical home country. The driver side floor pan is so rusted you can see the road below while driving. One day it just fall off while we were checking/pushing it to see if it still safe to drive. :D
  16. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    My old Jeep was like that. I pop riveted some aluminum and screwed in a piece of plywood.
    Tom
  17. bisco
    50,804
    that way, you can push with your feet if you run out of gas. fred flintstone style.:D
  18. bisco
    50,804
    my tr4 was like that as well. in fact, it was so rusted, i'm not sure what the front wheels were attached to.
  19. bisco
    50,804
    but back to topic, i have never pushed the accelerator pedal to the floor, ignition on or off. we're prius drivers, not cobra!
  20. qbee42
    18,058
    3,076
    Northern Michigan
    I have. You should try driving your fully loaded Prius through 12,000 foot passes out west.
    Tom
