Accessing/removing the instrument cluster in a Gen II ?
Discussion in 'Gen 2 Prius Technical Discussion' started by caffeinekid, Sep 3, 2011.
  1. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    I just bought a 2008 Prius that has some nasty haze accumulated on the inside surface of the speedometer display cluster. Can anyone direct me towards a disassembly diagram/PDF for the dash, or procedure for accessing this area sufficiently enough to remove and clean the surface? :)
  2. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    The display you see is a mirror image of the display that lies flat in the top of the dashboard (difficult to see) make sure this is clean before dismantling anything. IN ready mode slide a flat card or magazine toward the dispay to see what I mean.
  3. caffeinekid
    334
    44
    Houston
    Yeah. Unfortunately the contamination is on the underside and cannot be cleaned without removing the dash so far as I can surmise. It would be nice to have a service manual for the removal procedure.
  4. northwichita
    481
    102
    29
    Wichita KS
    Dash , combination meter removal. My display is also hazy, . Edit - I cleaned mine Jan 2012. Nice bright display now.
    Powered by Google Docs
    zeroreality.net/prius/repair/71%20-%20Instrument%20Panel%20meter.pdf
    Also found this webpage, more concise-
    http://ingineerix.com/cmremoval/
    Tips, air bag use 12 mm socket, very tight bolts and corner pieces comes out as one piece, disconnect top part as described in ingineerix.com, then work the rest out.
    05PreeUs, bat4255 and caffeinekid like this.
  5. caffeinekid
    334
    44
    Houston
    Thanks a lot. That is exactly what I was looking for.
