Accessory Mode vs. Just Sitting in Park?
Discussion in 'Gen 3 Prius Main Forum' started by bighouse, Feb 11, 2010.
  1. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Sometimes when I pull into a parking space I may be listening to something on my radio that I don't want to stop listening to. As such, I'll put my car into Park with the Park button, engage the parking break and just sit there and listen.
    It occurs to me that, in the old ICE days when my car was idling, I would NEVER do that. For lots of different reasons, not just burning of gasoline. So, I'm wondering, is it okay to do that after you've parked your Prius, or should I go through the Power Off and then hit the Power button (no foot on brake) to fire up the accessory mode? I sometimes don't want to miss anything on the radio though, so I don't really want to do that.
    Is there any potential harm or damage or wear I'm putting on the car if I don't shut it off and hit the button again? Seems to me I'm wearing down the Power button needlessly!
  2. JeffyJosephNCa
    JeffyJosephNCa TCH & Newbie Prius Owner
    45
    Elk Grove, CA
    I read somewhere on this forum to not put it in Accessory Mode because it would deplete the 12V battery faster if I'm not mistaken, but to put it on ON (hitting the button twice w/o pressing the brake so the ICE doesn't engage later). I've always wondered what was the best thing to do as I'm usually the driver and my family does a quick run to the grocery store or post office...
  3. krmcg
    2,592
    2,391
    Whittier, CA
    You have it right. ICE will fire up to keep the 12 volt battery charged up. If you put it into Acc mode, the battery could discharge and when you want to depart, your Prius may not start. (It happened to me - once).
  4. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    Leave it in Park, just don't forget to turn the car off when you leave. This is easier to do in a Prius since the ICE probably won't be running as you exit. This ensures you won't deplete your 12 volt battery and get yourself stranded.
  5. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    If it is less than one hour, my recommendation is switching to the accessory mode.
    The system automatically trun off the accessory mode after one hour. (page-165 of owner's manual)
    Prius consumes more than 200W electric power in ready mode and less than 30W only for listening the radio (without truning on headlights) in accessory mode.
    Therefore, we need more fuel to recover the charge level in ready mode than the accessory mode.
    Ken@Japan
    5 people like this.
  6. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    At work I will sit in my car at lunch and listen to Xm.
    I let the car warm up,need the heater its winter here in MN.
    than I put it in EV mode, seems to work for me!!
  7. ed_k1
    ed_k1 New Member
    ohio, usa
    I have a question that might be explained in the manual when I don't remember if or how to do this. When the system is in Ready mode and sitting Park, is there a way to transition to Accessory Mode other than turning the car off and then on again (with foot off the brake of course)?
  8. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Not that I have found, I think the only way is what you described. Go completely off then to accessory.
  9. Tideland Prius
    16,402
    funny how the non-electronic shifter cars (e.g. Camry XLE, IS, ES etc etc), you can shift into N before pressing the POWER button to switch to ACC. Can't do that in the Prius.
