Actual PiP eGallon - Is this correct or even useful?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JohnSNY, Jun 12, 2013.
  1. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    I wanted to know what the PiP's actual eGallon was compared to real world mileage of a Prius. The US government uses 28.2 MPG as the comparison on its website. That makes no sense for us PiP users who are getting 51 MPG according to the EPA.
    Please let me know your thoughts. I might be wrong on this. I hope that someone in this group can provide constructive input.
    I am using 12% for the assumed charging loss, and I pay 19 cents per kWh. I used 1009 kWh to drive 4273 EV miles (as of last month). My actual MPG in hybrid mode is 58.79.
    The formula that I am using is as follows:
    (kWh drawn * cost per kWh) / EV miles driven = cost per EV mile
    ((1009 * 1.12) * .19) / 4273 = .0502 cents per EV mile
    cost per EV Mile * actual MPG = eGallon for my PiP
    .0502 * 58.79 = $2.95
    Accordingly, it cost me $2.95 to drive the same distance using electricity as my PiP would have traveled using gasoline in hybrid mode. I am using MPG as reported by the car which is "optimistic." This number can't be perfectly accurate because hybrid mode also borrows from (and gives back to) the traction battery, so the result is an estimate.
  2. 3PriusMike
    3,061
    2,397
    Silicon Valley
    Math OCD: If you are assuming a 12% charging loss then you want to divide by 0.88 rather than multiply by 1.12
    Mike
  3. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    Thanks.
  4. jfschultz
    jfschultz Active Member
    636
    115
    Germantown, TN
    2020 Prius Prime
    Another approach would be to use the kWh of energy in a gallon of regular gas. There seems to be some variance, but 33.7 kWh/gallon seems to be a good number. This really points out how inefficient the gas engine is when one computes the EV MPGe. On my first tank, using the EV ratio data, I got about 160 MPGe!
  5. bisco
    50,801
    if i get 15 miles per charge at a cost of .50, and 60mpg in hybrid mode, does that make my egallon $2.00?
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    The calculation looks right.
    Regular gas around here is $3.80 so you do save some money using electricity.
    You'll have to keep in mind that, if you have to do many short trips, gas engine won't give you 58.79 MPG that you are getting.
    There is synergy going on with PiP. EV miles are cutting out the MPG killing short trips. Gas engine is weeding out electricity sucking high speed driving. The way each fuel are designed to use is boosting each other's efficiency.
    To put it another way, if you have a pure EV, you won't be able to achieve 236 Wh/mi since it'll have to cover highway driving as well as uphills. If you have a regular Prius, you'll likely get around 50 MPG because you'll have to do short trips that require engine warm ups.
    I think it is good that you can go 59 miles with PiP for $2.95 with electricity and $3.80 with gas. Note that, you can't go all 59 miles with only electricity or only with gas. It has to be a blend of both in order to achieve that low cost.
    So, what's your EV ratio?
    RBooker and Tracksyde like this.
  7. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    Good points. Since the EV and HV are "co-dependent" it's not fair or accurate to compare a PiP to itself using eGallon.
    My lifetime EV just hit 68% (which is the highest it has ever been).
    I think eGallon makes sense in the real world to compare an electric vehicle to a gas vehicle. I don't find MGEe to be useful in that regard. When advocating for electric cars, it makes sense to argue that "for every gallon of gas you buy for your ICE SUV, you could pay about a dollar to go just as far with electricty." I would like to see a website that allows a user to input information so that comparisons can be made between actual gas and electric cars. This type of information will help convince people of real long term cost savings.
  8. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    Yes, but usbseawolf2000 just pointed out that the comparison of a PiP to itself is not really fair.
  9. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    I understand, but I don't find MPGe to be informative. I get it that it allows comparison between vehicles that use different fuels, but eGallon tells me what I want to know. I think people will understand and be pursuaded by eGallon.
  10. bisco
    50,801
    agreed.^
  11. bisco
    50,801
    i disagree. if i don't plug in and get 60mpg, it's fair to compare that to pure electric driving.
  12. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    If gas is $3.50/gallon then 15 miles for $0.50 is 7 times 15 equals 105 mpg of equivalent cost.This is close to the EPA rating of 95mpg based on 33.7 kWh equivalent in energy to 1 gallon of gas.
    Of course if you can get your charge for $0.15 (California PG&E rate E9 at night) its even better cost wise.
  13. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    Sure, if you don't plug in, then it's fair.
  14. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Those are all very good points.
    On the other hand, he certainly "could" achieve 268 Wh per mile driving entirely in EV (236 doesn't including the assumed charging overhead). I averaged about 250 Wh per mile driving 1029 miles under a variety of typical conditions last month primarily on the highway in my 2011 Volt in EV mode. The PiP is at least as efficient in EV and maybe a little better. Some other all-battery cars appear to have comparable or better efficiency.
  15. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    That's around 210 Wh per mile. I'm guessing you aren't including charging overhead which is how EPA reports MPGe estimates. With charging overhead it would be roughly about 140 MPGe which is very good.
  16. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    If you get 60 MPG for all types of driving that you do, it would be fair to compare. The same goes for electricity -- if you get 15 miles per charge for all type of driving.
  17. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    That's pretty good. May I ask at what speed?
  18. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I typically set the cruise control at 56 mph but occasionally drive up to 65 for short stretches. City driving is at the posted speed limit. Most of my electric miles are on flat highway but a few days a month when I'm running later than usual and want to avoid bad traffic I take highway 280 which has many substantial rolling hills for 40+ miles. I live in San Francisco now so some city driving includes substantial hills.
    I just checked my 12 consecutive month statistics:
    Total miles: 24,440
    Electric miles: 17,088
    Gasoline miles: 7,352
    Total MPG: 153
    Total gasoline: 160.21 gallons (US)
    Total electricity: 3,783 kWh (no charging overhead)
    EV efficiency works out to 221 Wh per mile or 250-260 Wh per mile (assuming 12-15% charging overhead).
    HV efficiency works out to 45.9 mpg. The average 2nd gen Prius on fuelly.com gets around 45.5 mpg and the average 3rd gen Prius Liftback gets around 48 mpg.
    I've checked the gasoline consumption on the Volt display vs. the pump for the last 6-7 tanks of gasoline and the Volt display has never been more than 1.2% optimistic and is roughly about 0.5% optimistic on average although I haven't tallied up the exact average yet.
    Update: I tallied up my last 6 tanks of gas. The pumps said I used 40.667 gallons. The Volt display says I used 40.42 so the Volt display is about 0.6% optimistic over those 6 tanks.
    So, I'm doing about as well on HV as the average fuelly.com 2nd gen Prius driver.
    F8L and usbseawolf2000 like this.
  19. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    56 mph is a smart choice because beyond that, the wind resistance gets so high that Wh/mi would be much higher. I think it is the reason PiP was designed to start the gas engine above 62 mph.
    You could do 100 mph in EV with Volt but that would be foolish/wasteful, considering the cost and recharge time of the battery.
    If I recall from your one week test with PiP, you got 65 MPG on regular gas.
  20. jfschultz
    636
    115
    Germantown, TN
    2020 Prius Prime
    Yes, I was using the kWh reported on the EV ration display.
