Advice regarding Solar sun roof
Discussion in 'Gen 3 Prius Main Forum' started by seasidetraveler, Sep 30, 2009.
  1. seasidetraveler
    662
    CA
    I have a 2006 Prius that I hope to sell in about 6 months for the newer Prius. One of the options that I am hung up on is the solar roof. I think the feature is very interesting and love the sun roof aspect, but how is it working for you (those that have it)? Does the car actually stay cool on hot days? What are all the benefits to this feature? Does the solar always power the AC or just when parked?
    I want the solar roof but can't stand the new base rims- the upgraded wheels are better but not available with the sun roof! EEK
    I now live in Central CA where there are HOT summers and think a car that cools itself while parked is a great idea.
    One more side question: Is the usb iPod port standard yet? I had heard that "later this year" it would be.
    Thanks folks.
  2. jaywolf
    jaywolf Member
    107
    Vincennes, IN
    Go with the sunroof for the cool factor. When anyone hears you ave a new Prius they will as do you have the "solar power sun thing" on it? Who want to say no.
    Fan only runs with power off. Solar has no function when the car is on other than to look cool.
    As far as wheels remove the hub caps and put on centers, it's a real nice look then for the cost of centers.
  3. seasidetraveler
    662
    CA
    Does anyone have a photo of what this type of wheel would look like?
    Maybe by the time I decide to buy they will have more uses for the solar? I have seen so many new Prii and can't believe that so many are w/o the solar.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    FYI, the solar panels never power the AC. They power fans that circulate air but not the AC. It's not cooled air. It's designed to attempt to keep the interior as close to ambient surrounding tempature. So if it's 90 degrees outside don't expect the interior to be less than 90 degrees. Of course it also comes with remote AC, which allows you to use the AC before entering the automobile.
    Personally, I'd want the Solar Package, for the sunroof itself. Everything else, the solar panels and the ventilation system might be nice, but I think I could live without those features.
  5. seasidetraveler
    662
    CA
    Thanks.
    I imagine the cooler interior ultimately helps the life of the battery pack?
  6. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    The SR looks cool and keeps the car "cooler" not w/AC. If you have the SR and then can flip the "remote AC" before getting to your car then it will really hep a lot. I just wish the car/AC stayed on once you opened the door but it shuts off when the door is opened. Even if just using the SR and window tint/heatshield you will have a significant improvement...no more blast furnace when you get in.
  7. Jayhawker
    Jayhawker New Member
    52
    AZ
    I would get the SR if I didn't have to get the NAV as thatis getting yanked out. Maybe down the road they will offer that as a seperate option. Who knows.
  8. seasidetraveler
    662
    CA
    I thought you can get NAV with the SR?
  9. claridiva
    claridiva New Member
    109
    Dallas, TX
    You can get NAV with SR; in fact, I think you can ONLY get the SR with NAV. The previous poster is suggesting he doesn't want to pay for the NAV that he intends to rip out to replace with another head unit.
  10. snoctor
    snoctor Member
    126
    27
    Davis, CA
    I got a model 3 with solar roof 2 months ago and live in the California central valley near Sacramento. So I have the same weather you have: hot and sunny. I took temperature readings inside the car with the solar roof running and with it not running. When the temp goes over 100 (as it does pretty often out here as you know) the internal temp in the car with the solar powered vent running still gets quite hot, but not nearly as hot as it does without the vent running. With vent running on a hot 100 degree sunny day the internal temp maxes out at about 125. Without the vent it can be 30 degrees hotter or more. I put my temperature measurements in another post (I think that post was called solar roof temperature report). I have a solar shield on the front wind shield, I keep my windows closed because I park in a dusty gravel parking lot, and I park facing north because the solar panel sloops down toward the back of the car and you'll get slightly more sun light falling on the solar panels that way. Many folks were surprised by the 125 F temp, but I think most of us just don't realize how hot it gets inside a car on a sunny day with the windows closed. The hottest reading I got was actually 165 F (car facing south without solar shield). Final note about taking temp: I took those readings after the car had been parked in the full sun for at least 4 hours.
    Now that the temps have been a bit lower on some days (especially the last 2 days) I can tell you that the vent works much better. Of course that only makes sense because blowing 80 degree air into the car will work much better than blowing 100 degree air.
    Couple more points: the sunroof in and of itself is really cool. Now that the temps are lower it's really nice to ride around town with the roof open. Some here on the forum have wondered if the sunroof cuts down on mpg because of added weight, reduced aerodynamics... etc. But over the first 2000 miles I'm averaging 53.8 mpg (my calculation, the car thinks that it's getting 55.8 mpg), so I'm pleased.
    Good luck!
  11. seasidetraveler
    662
    CA
    THANK YOU THANK YOU!! This helps me!
  12. tjp74
    tjp74 New Member
    92
    31
    Bothell, WA
    Yes and that's only way actually. If you want SR, you have to get NAV, packaged for $3600 (old price)
    Jayhawker was just saying he would have gotten SR if he didn't have to get the NAV.
    The factory NAV in Prius is a disapointment by many. Screen resolution is low, color is only 256 and doen't have whole lot of features considering the price. Some of us are even considering ditching the factory NAV and install aftermarket unit that has 800x600 pixel high resolution full color display with full featured DVD player, SD card slot, ability to use nav while in motion plus all kinds of fun features and can be bought off eBay for as little as $500 shipped.
    Back to topic, to me, having a sunroof is a must. I use it everyday if there isn't too much direct sunshine or not raining or if it's too cold. And what makes it even more desirable is the remote A/C plus the contrasting black roof making my blizzard white stand out from other '10 Prius on the road. Also it makes the car look quite intereting with the roof open.
    Regarding wheel, you can easily upgrade the basic 15" to factory 17". I recently saw a like brand new set sold for about $1300 including tires but no pressure sensor. Or you can order brand new set of wheels for about $1300 from parts.com and tires from places like tirerack for about $400 or so. and sell your 15" set on ebay.
    It's not cheap but to me, only thing I wanted from package V was LED headlight and 17" wheel but I figured it will be easier to add these two stuff to package IV comare to missing the sunroof on package V.
  13. Brucester
    Brucester New Member
    Toronto, Ontario
    I like the sunroof, but find the solar powered cooling to be of marginal use. The remote a/c can make a big difference, though.
    Also, fyi, in Canada, the SR is available without NAV:
    TOYOTA CANADA : Vehicles > 2010 Prius > Models
  14. pri-serious
    pri-serious New Member
    32
    LA
    I got my car a couple of days ago and I've been loving the SR. Thank you Snoctor taking the time to measure the differences in/out side without fan on.
    I get off work at 2pm having my car parked out in the sun for half a day. I noticed the difference is when I turn on the car, the fan goes off, and immediately I can feel the temperature rising while I sit in the car and check my iphone for emails/miss calls.
    if you're in CA, you should get the solar package, I'm very happy with mine
  15. jaywolf
    jaywolf Member
    107
    Vincennes, IN
    Re-posted with correction
  16. jaywolf
    jaywolf Member
    107
    Vincennes, IN
  17. Tideland Prius
    16,406
    I'm quite far north and I have the SR. It works well and I've gotten into a "cool" car when it's 30°C outside and I have no sunshade. I haven't had the need to use Remote A/C (mostly b/c I keep forgetting to take it out to press the button)
