after clean up fuel injectors, EGR, intake manifold, engine shaking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tamo3, Sep 21, 2024.
  1. tamo3
    tamo3 Junior Member
    23
    CA, USA
    After all the expert friends' input on this forum, we figured out the root cause of the problem was using fake spark plugs.
    Don't purchase spark plugs from eBay.
    My 2010 Prius has 120k miles on it.
    For preventive maintenance, I did the following.
    • - Fuel injection cleaning
    • - EGR pipe cleaning
    • - EGR cooler cleaning
    • - EGR valve cleaning
    • - PCV Vale replacement
    • - Water pump rotor replacement
    • - Intake Manifold complete cleaning
    • - Throttle body cleaning
    • - Spark plug replacement
    • Use new gaskets for all those area.
    It was working fine for few weeks.
    Now I got misfire #2, #4 while slow idle, If I step on gas to higher RPM, no shaking.
    I tried investigate whether it's a gasket leak or not.
    Findings:
    • I check compression for all cylinders following FSM. All cylinders have more than 130psi.
    • There is no coolant lost
    • No white smog comes out from the exhaust.
    • No coolant mixed was detected in oil visually.
    I replaced remanufactured fuel injectors with OEM O-rings and seat insulators but I can't fix the shaking.
    Could you advise me on what else I should check?
    Thanks in advance!!!
    #1 tamo3, Sep 21, 2024
  2. Tombukt2
    Tombukt2 Senior Member
    11,557
    2,030
    Durham NC
    This is very common on this engine and this model series so you're on the right track going everything you're going over but at the end of the day something's causing an imbalance in the power between the systems which is causing the shake generally it's something seeping through the head gasket it doesn't need to be a flood just seepage will do but usually that clears up pretty quickly and then the rest of your drive can be kind of normal till pressure builds up in the radiator and everything is nice and hot then it can rear its ugly head again because of the pressure. Sometimes relieving the pressure in the Degas bottle all of a sudden will make things clean up again this is generally a sign that the fire in the combustion chamber is being put out by something pressure in the coolant system
  3. tamo3
    tamo3 Junior Member
    23
    CA, USA
    One of the suggestion I watched on Youtube, unplug EGR connector to check whether it's caused by EGR or not, the symptom is not changed. Off course I completely clean up EGR line within intake manifold before.
  4. tamo3
    tamo3 Junior Member
    23
    CA, USA
    Thanks @Tombukt2 for your input.
    So.. what is your suggestion to look after? I'm not clear what action I should take.
  5. Leadfoot J. McCoalroller
    7,762
    7,239
    Pennsylvania
    2018 Prius c
    Are the new spark plugs any good?
    There are many bad counterfeits available from Amazon and eBay, so you need to be careful. Always better to get them from a local shop.
  6. tamo3
    tamo3 Junior Member
    23
    CA, USA
    Hi Leadfoot J.
    Spark Plug is OEM brand new one I used. Exact same model.
  7. vvillovv
    vvillovv Senior Member
    4,315
    1,494
    NY
    post a video of the shake, how long it lasts and the ambient temps at the time of the video. What part of CA you from North Midway or South?
    Take a look at a gasketmasters youtube and compare your shake to one of theirs.
  8. tamo3
    tamo3 Junior Member
    23
    CA, USA
    Hi @vvillovv
    Here is my video.
    https://youtube.com/shorts/UpmqcPZvmCc?si=CgzaRrEoGeRkmknZ
    By the way, I'm at San Jose, CA. Ourside temp is 70 degree now.
    #8 tamo3, Sep 21, 2024
  9. Eddie25
    Eddie25 Active Member
    461
    187
    IL
    My wild guess would be missed a hose connection on the intake manifold. They are hard to see under there. Double check that you don't have anything that could cause a vacuum leak.
    All EGR gaskets were replaced correctly?
    You could try simple misfire checks like switching the coils and spark plugs between cylinders, but that seems less likely.
    Edit: My bad, by "it was working fine for a few weeks" do you mean after the maintenance?
  10. tamo3
    tamo3 Junior Member
    23
    CA, USA
    Hi @Eddie25,
    Yes, after the maintenance was done, it worked fine for a few weeks. All EGR gaskets are replaced with new one with the correct direction facing.
    It started misfiring while the engine is not warmed up, but now it won't stop shaking.
    #10 tamo3, Sep 21, 2024
  11. Tombukt2
    11,557
    2,030
    Durham NC
    That spark plug packaging looks totally fake to me I don't even recognize the packaging and I've dealt with nippondenso for quite a long time but I don't keep up with their latest packaging schemes as a lot of it seems like they're not changing their packaging schemes to counterfeiters are or something just doesn't seem right to me but I could be very wrong they just don't look correct I would go to the Toyota dealer in this instance and buy four spark plugs and try them in the car and see if that clears up the nonsense If you take the four plugs you just put in let me see pictures of those out of the car and I know it sucks but. These counterfeit plugs start to look like they have 100,000 mi on them in a couple of weeks some of them will fall apart in your engine.
  12. ChapmanF
    16,949
    Yeah, the important question is "purchased where?".
    If counterfeiters used a different brand name or model number, they wouldn't be counterfeiters.
    Brian1954 likes this.
  13. Mendel Leisk
    40,235
    The misfire code started after the plug change?
    Swap 2 and 4 with 1 and 3, see if the code changes. Also inspect the plugs carefully while they're out.
    If the code changes (to 1 and 3) and/or the plugs look beat up, probably they're fakes.
    If not, I'd boroscope inspect the combustion chambers, first thing in the morning, after the car was driven the previous day, looking for evidence of coolant leaks.
  14. Tombukt2
    11,557
    2,030
    Durham NC
    Does anyone recognize the spark plug packaging please?
  15. Mendel Leisk
    40,235
    Lotta languages on the box, for a north american plug. Up here it'd be English and French, full stop.
  16. tamo3
    tamo3 Junior Member
    23
    CA, USA
  17. Tombukt2
    11,557
    2,030
    Durham NC
    Yeah I don't think so my friend I would be wanting to have a look at those real quick like You've been how many thousand miles how many weeks this would peak my interest very quickly. I know I pulled one set that I bought out of my 2013 since the install of the engine and I've checked them twice. But the cheap fakes with not even a month on them look like they were deteriorating very rapidly like they wouldn't make another month or two I might even have them around here I need to pull them out and make pictures I guess
  18. ChapmanF
    16,949
    Also, some counterfeit plugs will eventually drop a chunk of ceramic or metal into the cylinder. Undesirable.
    douglasjre likes this.
  19. tamo3
    tamo3 Junior Member
    23
    CA, USA
    I understand those are fake set. Especially #4 is so bad.
    I compared with original set.
    I will re-install original set while waiting new sets.
  20. Leadfoot J. McCoalroller
    7,762
    7,239
    Pennsylvania
    2018 Prius c
    Sometimes the price is enough to tell you. A single genuine SC20HR11 is currently $8.46 at Rock Auto, and about double that at Autozone.
    If you've seen a lower price, be very suspicious.
    Denso's own statement
