After market Prius batteries??
Discussion in 'Gen 2 Prius Technical Discussion' started by mocnarf, Jul 21, 2007.
  1. mocnarf
    mocnarf New Member
    Is it likely that sometime in the next couple of years that
    we will start seeing "after market" batteries for Prius?
    And hopefully, bring the price down to something a bit
    more reasonable.
  2. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Right now there are companies like Hymotion getting ready to market plug-in batteries to give you usable EV range but we're talking $10k for the conversion. Some folks around hear (Cheap! and at least one other guy) are doing their own add-on projects using relatively inexpensive but heavy lead-acid batteries for a whole lot less money. (Couple grand maybe?)
    Who knows what's next. Toyota doesn't seem happy about people converting their cars to plug-in so it's going to be a tough market to grow, especially given the prices.
  3. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    I'm betting he is talking of the 12V one. It's a little overpriced, at $250 and up. For what it is. Haven't seen one yet, but there may be a close enough one made for motorcycles. Or one of the motorcycle battery manufacturers may do that size soon.
    At the Toyota price, I'd go the Optima route (size 51 Yellow top). You get a much higher capacity sealed AGM battery. Just have to do the fitting/hold-down/connection conversion. They cost around $220.
  4. richard schumacher
    7,664
    1,042
    United States
    <div class='quotetop'>QUOTE(David Beale @ Jul 22 2007, 10:32 AM) [snapback]483134[/snapback]</div>
    Is an adapter kit available? I'd rather buy a well-engineered solution than cobble something together.
  5. 1fixitman
    1fixitman Member
    182
    Augusta, GA
    <div class='quotetop'>QUOTE(richard schumacher @ Jul 22 2007, 01:41 PM) [snapback]483180[/snapback]</div>
    I had Oriley auto parts in Augusta, GA call optima to order me a size 51 optima yellow top. Optima told the guy at Oriley's that the Optima 51 yellow top was discontinued and NLA (No longer available). :( I was considering this for my car as an upgrade so we are back to the drawing board or Hobbit's post on battery removal and pics and measurments. Sorry for the bad news. You are willing to do the call on your own and do your own DD on this issue. Please post if you find a great inexpensive way to make this happen.
    D Rock
  6. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(D Rock @ Jul 22 2007, 02:55 PM) [snapback]483212[/snapback]</div>
    The Optima 51r battery (reversed terminals) was pulled by Optima when many of them started to exhibit early failures. There is a Duralast 51r (Autozone) which should be fittable and, of course, you can buy a kit on ebay consisting of a decent miata-sized battery and adapter parts which was originally put together for the classic Prius.
    JeffD
  7. mo04prius
    mo04prius New Member
    My recommendation is Odysseybatteries (Heavy-Duty and Miltary Grade,
    AGM (Dry Cell) Batteries, which can be put on there side and they are
    used in these industries: car audio and racing (on and off road vehicles),
    ATV's, Watercraft, Motorcycles, Marine, and especially commerical use.
    Global Headquarters
    EnerSys
    P.O. Box 14145
    Reading, PA 19612-4145, USA
    Tel: +1-610-208-1991
    Toll-free: +1-800-538-3627
    Fax: +1-610-372-8613
    Regional Sales
    EnerSys Energy Products Inc.
    617 N. Ridgeview Drive
    Warrensburg, MO 64093-9301, USA
    Tel: +1-660-429-2165
    Fax:+1-660-429-1758
    EnerSys Limited
    Rake Lane,
    Clifton Junction,
    Manchester M27 8LR UK
    email
    Tel: +44 (0)161 727 3952
    Fax: +44 (0)161 727 3805
    EnerSys Australia Pty Ltd
    7 Walker Place,
    Wetherill Park, NSW,
    Australia 2164
    Tel: + 61 (0) 29756 1870
    Fax: + 61 (0) 29757 4537
    Toll-free: 1-800-550-153
    1a) Enersys Corporation
    http://www.enersysreservepower.com/ody_b.asp?brandID=5
    1b) Enersys Corporation - Factory in Warrensburg, MO
    http://www.odysseyfactory.com/
    1c) ODYSSEY Battery Specs
    http://www.odysseyfactory.com/specs.htm
    1d) ODYSSEY Sales
    http://www.odysseyfactory.com/odybuy.htm
    2) Master Distributor of Odyssey Drycell Batteries:
    West Coast Batteries Inc.
    410 Le Roy Drive
    Corona, Ca. 92879
    Toll Free (888) 379-2555
    http://www.odysseybatteries.com/
  8. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Try the Kinetik HC 1400, it is 60 AH, used alot on the sound-off circuits. E-bay has them all the time.
    Wayne
