Air Con not working in Accessory Mode?
Discussion in 'Gen 3 Prius Technical Discussion' started by Mister Neutron, Aug 16, 2009.
  1. Mister Neutron
    Mister Neutron New Member
    Bally England
    Hi All,
    Still very new to the Prius, so this may just be a 'RTFM' issue, but I noticed that the air conditioning stops when stationary and in Accessory Mode. Is this normal? I'd have thought that you'd want the A/C to be fully functional when parked in the sun, rather than just having the fans working (which is all I got?) :(
    When everything was powered fully back up, 'Ready' on and moving, the A/C quickly cooled me down, but... :confused:
  2. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    Remember, the AC is working off the battery, if you were to use it in Accessory, you would quickly run down the battery, its designed to work in Ready, so that the engine will come on, if needed, to make sure the battery doesn't drain. Just put it in Park while its in Ready.
  3. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    My a/c operates in accessory mode, no problem. I always have it set on auto, so I don't know how it would respond in manual mode.
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I don't think your ac works in accessory mode. That mode runs off the tiny little battery, I am pretty sure you need to have it in ready mode, so the ac can run off the HV batt.
  5. Mister Neutron
    Bally England
    ...Yeah, I guess the Aux battery would be flattened if it tried to run a 'fridge for too long! ;)
    I'll ensure it is in Ready mode but with the Hand Brake on - job done.
    Cheers, everyone.
  6. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    Perhaps I'm misunderstanding, but you mention the parking brake but not transmission. You're putting it into Park as well, right?
  7. patsparks
    10,664
    567
    Adelaide South Australia
    To prevent you prius surging when parked in ready mode if you apply the park brake firmly, then apply power in drive then hit the park button. this loads the transmission slightly and prevents the car shaking when the engine starts.
  8. bwilson4web
    15,929
    Ok, I missed it in the Owner's Manual. How do you get "Accessory Mode?"
    I keep turning on the car to "READY" when all I want to do is roll down or up the windows while getting strapped in and getting everyone else ready to go.
    Thanks,
  9. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Foot off brake and 2 pushes on power button when parked.
  10. royrose
    royrose Senior Member
    1,389
    951
    Foot of Pikes Peak
    You hit the start button without your foot on the brake.
  11. Tideland Prius
    16,401
    1 push.
    2 pushes gets you to IG-ON (or ON in other cars). 1 push gets you to ACC or accessory.
    AFAIK, no car runs the A/C unless the engine is on and it's no different in the Prius. The car must be in READY mode before the A/C compressor runs. In IG-ON mode (2 pushes of the POWER button without pressing the brake pedal) simply gives you the fan like any other car.
  12. jay_man2
    1,246
    144
    Manassas, VA
    When you hit the power button once without a foot on the brake the radio comes on. Hit it again and the fan starts blowing and the rest of the dash lights up. All I know is every time I've done it I get cold air from the vents, but that may just be the fan pushing already cold air around.
  13. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    That's because you just turned the car on with the second press.
    The little 12V battery won't run the AC compressor. It could probably run the blower (don't know if it does or not as I haven't tried.) Conventional cars can't run the actual AC compressor with the engine off since it is belt driven off the engine. The Prius can use power for the traction battery to run it when in ignition on mode.
