Air flow from fans with AC on max.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beachbummm, Sep 22, 2013.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    still working on the ac problem, both fans are blowing IN towards the motor with the AC on max, inside fan on high.(blower was replaced by dealer 5/13)..still no cold air..is the air flow correct?
    Thanks :cool:
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
  3. Beachbummm
    1,160
    392
    thanks!
  4. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Doesn't sound right, if the air flow is being sucked into the registers instead of blowing out. Might the fans electrical connections be backward causing the fans to run in reverse? What does the dealer say?
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The OP is talking about the fans behind the radiator. The fans need to pull air through the radiator and exhaust towards the motor, just like when the car is moving.
  6. SteveLee
    645
    180
    North Carolina
    I
    Ahhh, thanks for the clarification.
  7. Beachbummm
    1,160
    392
    dealer says at least $250 every time they open the hood...thats why Im trying to fix it myself
  8. Beachbummm
    1,160
    392
    it seems the filter in the dryer is clogged with oil and bits of old compressor.the filter sock was almost black when I removed it, it was just put in with the 3rd compressor in may 2013..I have no idea why two shops didnt check this..Im betting the expansion valve in blocked with metal shards..I was told from a local shop $400 for the labor plus parts with no clue if it will fix the problem or not...I hope its a long cool winter so I dont have to worry about it for a while.
