Air Flow Meter Malfunction after service
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by justmulc, Apr 9, 2011.
  1. justmulc
    justmulc New Member
    Vancouver
    I just had my 2007 Prius serviced. After the service, my car broke down within 10km of the shop. The shop determined that the air flow meter had malfunctioned and wants to charge me about $500 to replace the part. Could the air flow meter have been damaged when the vehicle was being serviced? Specifically, when the air filter was removed and inspected during the servicing. It seems plausible that shop did something to cause the problem. Any thoughts?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I damaged the maf on an MR2 I owned once. I changed the air filter myself and inadvertantly damaged the maf in the process. Not sure if the maf is in the same place on the Prius but the MR2 was also a Toyota so who knows?
  3. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Changing the air filter on a Gen 11 would/should not interfere with the MAF Sensor unless something was dropped down where the sensor sits,I had a problem recently and one of the things i did was to clean the MAF with the proper cleaner[CRC MAF Sensor Cleaner]
    Maybe give that a go first,if it does need a new sensor,get it yourself and fit it,it's an easy fix if you're anyway DIY inclined.
  4. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    (This thread should have been placed in another subforum)
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    Yes they could have damaged it but if they did they will probably never admit it was their fault. Could also be a coincidence and it picked that time to fail.
    Do a Google search for "2007 Prius maf" the first thing that comes up will direct you to 4 maf sensor topics on this site.
    As previously mentioned you may be able to get by with cleaning it if it's not damaged. It would be nice it you could get a second opinion.
  6. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    New member [April 2011]
    If i can help,i will,regardless of where it's posted,as i'm sure most other members would.
    I'm sure with time,the OP will get the hang of things.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  8. telmo744
    2,181
    769
    Portugal
    Of course. :)
    Thank you for remembering the best practice established. :)
