Am I Missing Something?
Discussion in 'Gen 3 Prius Technical Discussion' started by JimN, Jul 1, 2009.
  1. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    These photos were taken yesterday at the NJ Prius meet. It seems to me that the unshielded wiring is going to be a dirt & grime collector. Do you have exposed wires or a plastic shield on this component? Barbara needs to know if she needs to make a trip to the dealer.
    Thanks.
    Jim.
  2. CtrlAltDelete
    CtrlAltDelete New Member
    Daphne, AL
    Mine is the exact same way.
  3. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Hi Jim, I just checked mine and it is exactly the same as in your pictures so Barbara doesn't need to worry about planning that trip just yet.
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I noticed that on Wayne's 2010 at our last Prius meet.
  5. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Looks like Toyota didn't protect them. I would find a way to add your own protection. Maybe some clear RTV will do the job. After years of road dirt, grime, exhaust, oil, etc, enough junk could build up and cause intermittent problems later.
  6. 12parsecs
    12parsecs Junior Member
    56
    MD
    The wires connecting the car's horn(?) look very fragile too, as if getting hit by some gravel would break it.
    In Toyota we trust!
  7. JimN
    7,028
    1,116
    South Jersey
    I believe we've found another advantage for 2010 grill blocking. I also vote for finding something to cover that up. Thanks everyone.
  8. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I'd argue it'd be pretty hard to get something high speed and damaging flying up in there unless something pretty significant was going on (i.e. front end collision). Most of the airflow will be "filtered" by our poor radiators and A/C condensers before making it into the engine compartment. With the amount of panels below, most of the air will be "exhausting" down there vs. entering.
  9. djasonw
    djasonw Active Member
    958
    119
    Coconut Creek, FL
    I'll have to look at mine tomorrow. It is a 2004. Why not just protect it with some duct time loosely around it?
  10. RMulligan
    RMulligan Junior Member
    Hawthorne, CA
    Four Touring
    Those aren't the only wires with exposed connectors. Just follow the cable from the picture around to the left side of the Power Control Unit and you will find another set of exposed connectors. Perhaps a Toyota guru can explain the reason for this type of connector design and whether they considered making a cover for the connector.
  11. tiztim
    tiztim Junior Member
    49
    Chicago
    duct tape adhesive exposed to heat, freeze, humidity would give you a disgusting, gooey mess.
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    My 97 Camry was the same way. Many of the connectors looked like this and yes, they were a grimmy, dirty mess. After a 126K miles did I have a problem, no, at least not the I am aware of.
    Peter
  13. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Pretty sure you are just looking at bare wires, that the pins that are crimped on the wires are pushed through a rubber seal into the plug giving a water proof seal. I would not "pot" the backside of the plug as it could make removing the wires at a later dater very difficult.
