AMSOIL not API certified?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Muleears, May 15, 2006.
  1. Muleears
    Muleears New Member
    22
    Windsor, VA
    I was reading an article about oils when I came across this statement about Amsoil " Amsoil has one product line, XL-7500 that is API certified, but it's other lines contain too much ZDDP to be certified and should not be used in vehicles with catalytic converters." Has anyone else heard this? It somewhat concerns me as I know the catalytic converter on the prius is not a standard or cheap converter. Mine also has Amsoil in it now! The article this came from is http://www.nordicgroup.us/oil.htm#Sludge (The jist of the article is to debunk the need for 3000 mile oil change intervals.)
    I have only heard good things about amsoil, does anyone else have any thoughts?
  2. tochatihu
    tochatihu Senior Member
    9,457
    3,655
    Kunming Yunnan China
    2001 Prius
    You should visit the extensive discussions on the internet group "Bob is the oil guy" Just google bitog. I suggest that the phosphorous/catalyst question is a very good one for you to present there.
    They also have a virgin oil analysis library there which shows two (other) versions of AMSoil with about 1200 ppm P. Mobil I has about 700 ppm P. I cannot tell you if this difference is critical.
  3. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Amsoil's site says:
    http://www.nordicgroup.us/oil.htm was last updated in 2002, so maybe things have changed?...
  4. huby
    huby New Member
    Illinois
    Most of the Amsoil oils are not API Certified. The only ones that are certified are hydocracked/hydro processed group 3 (petroleum) XL series oils, and the Diesel Blend -Hence the name "American Petroleum Institute"
    The main reason IS the phosphorous level. Does phosphorus damage cats? Yes! This isn't the only reason.
    But, only if the oil volatilizes/vaporizes and ends up in the exhaust stream or the engine burns oil. If you have any engine that burns oil will damage the cat anyway! The phosphorus rating from the API is to protect the cat for 150,000 miles.
    If you were to use a petroleum oil or synthetic oil and change every 3000-5000 miles and this oils had the low NOACK rating you are going to introduce just as much if not more phosphorus into the exhaust stream, which could damage your cat. The maximum allowable NOACK volatility percentage is 15%. Most of Amsoil oil are in the 5-8% range. In many cases more than half less than the allowable limit than set by the API.
    Since 1972 Amsoil has been formulating oils for performance and reduced engine wear while extending drain intervals. Now I know that cats have not been used since 1972 but how many people have you heard of that run Amsoil and damaged cats?
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    The AMSOILs you would be putting in a Prius are API certified. This is very old info you are dealing with. AMSOIL does not even offer a non-API oil available for the Prius presently. The Gen I and Gen II would use 0W-30 or 5W-30, both API certified. The Gen III uses 0W-20 which is API certified. Since I have all of the above cars and have been using AMSOIL for many years now with over 10+ UOAs, I have the proof that the 0W-30 is a very good long life oil. It will take some time to evaluate the new 0W-20.
  6. huby
    huby New Member
    Illinois
    Actually this is not old info. The ONLY API Certified oils "the API starburst" by Amsoil are the XL (group 3) line and the diesel blend.
    Not that this is a bad:)
  7. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Your right, I'm wrong. I went back and read the fine print on the oil containers. "For use in engines that use API certified oil..."
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    You brought up the KEY points right there!
    An oil that will last 20,000 miles with no noticeable oil consumption, is far better for the motor and the emission controls, than an oil that is changed every 3,000 miles and uses half a quart between changes
    Remember that the bare minimum spec API oils are designed to shear ON PURPOSE. Thus, oil consumption
