An new old sound
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SteveLee, May 18, 2014.
  1. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    135k miles on the 05 and the tires were wearing low. I got the car with 96k and what I assume were the second set. So at 135k it's about time. Thinking I was hearing the wear bars I changed the tires to Ecopia EP422. Made some difference in the ride. The handling isn't much if any better, still a little flighty now and then. But the sound of what I thought was the wear bars is still there and the slower the louder and can even feel the thumping. I don't hear any other discernible errant sounds. I have an idea what it is but I wanted to run it by the other Prius heads here to get your thoughts. Still lovin the car.
  2. JC91006
    16,632
    8,492
    wheel bearing sound?brakes? what do you think it is?
  3. SteveLee
    645
    180
    North Carolina
    I
    I don't think brakes or wheel bearing. It is heard without applying brakes. The thumping does not seem like a bearing noise. It's too regular and distinctly intermittent, like the wear bars of a tire. I was thinking maybe a CV joint even though I haven't noticed any clicking in turns.
  4. Former Member 68813
    3,524
    983
    US
    When bearings are very worn out there will thumping all right. The next thing happens is wheel is loose. Don't ask how I know. Does it change with turns?
  5. SteveLee
    645
    180
    North Carolina
    I
    Doesn't seem to change in turns but I did find it rather odd that with new Ecopias it slightly lurches off to one side a little.
  6. JC91006
    16,632
    8,492
    sometimes this lurching has to do with the crowns in the road......or your alignment is slightly off. Try rotating the tires and see if anything changes.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    No such thing as wear bars on tires.
  8. Former Member 68813
    3,524
    983
    US
    If no change in noise while turning, then bearing not likely. Please let us know when you figure it out.
  9. SteveLee
    645
    180
    North Carolina
    I
    Ok, Ed, thanks. Does Tread Wear Indicator sound better?
  10. SteveLee
    645
    180
    North Carolina
    I
    Yeah, the sound is not so noticeable at highway speeds but in town. And it gets more pronounced the slower I go.
