Another Hid Question
Discussion in 'Gen 2 Prius Technical Discussion' started by ThePackage, Feb 14, 2008.
  1. ThePackage
    ThePackage New Member
    74
    I am curious about how the HID headlights go from low beam to high beam. Are their two separate filiments in the HID bulb or is their some other kind of mechanism? Also, is it true that the OEM bulbs are D4R with a color temperature of 4300K? Thanks for your help.
  2. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    The Prius HIDs have a small lens "blocker" that mechanically moves to block or allow more of the HID light. So, in effect, the HIDs are always full on, but on low beam a portion of the light is blocked by this do-hickey. Must be a better name...
    No clue on the temp of the other bulbs.
  3. ThePackage
    74
    Thank you "Finman" for getting back to me. Do you know if that "shutter" is part of the bulb or part of the headlight assembly?
  4. PRIUS007
    PRIUS007 James Bond -007
    133
    Mundelein, Illinois
    I think it's part of the assembly and not the actual HID bulb. As for the color, I think most facroty HID's are 4300K.
  5. tedmarshall
    tedmarshall New Member
    25
    San Jose, CA
    The shutter is definitely not part of the bulb but is the metal "crown" over the tip of the bulb. If you watch a Prius HID from the side (so you don't get blinded) while someone flashes the brights, you will see it move.
  6. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    D4R is correct.
  7. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    The manual on my '07 Touring calls out a D2R.
  8. ThePackage
    74
    Thank you all for the information.
