Antenna removal procedure
Discussion in 'Gen 2 Prius Main Forum' started by Wendel, Jan 30, 2006.
  1. Wendel
    Wendel New Member
    The manual advises to remove the antenna before washing the auto. Unfortunately it does not say how to remove the antenna. What is the procedure for doing this? Or should the antenna even be removed?
  2. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    Gently grip the antenna just above the base, you will see the hairline split. Twist and it should un-screw quite easily.
  3. jared2
    jared2 New Member
    1,615
    Don't forget to turn counter-clockwise to unscrew.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Lefty-loosey
    Righty-tighty
    I took mine off as soon as I bought my '04 Prius. The winter road salt has a nasty habit of getting into *everything* and parts can seize. Knowing my luck, at some future point I would have to remove the antenna and it would be corroded on.
  5. Wendel
    Wendel New Member
    Thanks for the information!
  6. Tideland Prius
    16,559
    It's recommended to remove it while going through an automated car wash that uses brushes. If it's touchless, the antenna should clear the overhead machine.
  7. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    Early on, I replaced the OEM antenna with a stubby (2") antenna I bought on eBay to avoid having to remove the antenna for car washes. I have not noticed any degradation of FM or AM signal strength in my metro (Dallas) area. I do reinstall the long (OEM) antenna when driving cross-country for better reception on weak stations.
    Search eBay on "car antenna" or similar.
  8. kpauley
    kpauley New Member
    149
    Gilroy, California
    After unscrewing, is there a way to access / remove the base? I was thinking about pulling my satellite radio wire through there instead of through the hatch, that is if it's simple enough to get the base off.
    Anyone pull the base off before?
    Ken
