anti-theft question
Discussion in 'Gen 2 Prius Technical Discussion' started by fogg8920, Dec 31, 2006.
  1. fogg8920
    fogg8920 New Member
    I am currently researching the idea of buying a Prius and am trying to get my mind around keyless driving. So you push a power button to start the car. So what's to keep a would-be car theif from breaking into the car and pushing the power button? I see there is an "anti-theft" option that one can buy, but it's in a package with a bunch of other expensive bells and whistles that I'm not interested in paying for. How can you protect your Prius from theft without buying a bunch of electronic gizmos?
    Fidelma
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    To start the Prius you must have the FOB or "Key" in the car when you press the power button. Pressing the power button without the key will result in nothing happening. The only easy way to steal this car is to get a flatbed tow truck.
  3. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Fidelma @ Dec 31 2006, 03:33 PM) [snapback]369074[/snapback]</div>
    As far as I can tell, the Prius is one of the more difficult cars to steal. While there's little to keep a theif from breaking in and pressing the power button, there is plenty to keep that action from actually starting the car.
  4. Tideland Prius
    16,402
    The car cannot start without the fob inside the car (whether it's in the dash slot or in your pocket). Just like any other car, you have to have the key.
    Every Prius comes with an engine immobiliser as standard equipment. This disables the engine unless the proper key code is recognised.
    The "anti-theft" system you're seeing as optional on upper packages is simply the alarm and nothing more.
    Also, because of the electronic slot and push-button start, it's harder to hotwire.
    Lastly, if you're really in a shady part of town very often, have the glass-breakage sensor installed (must have some sort of alarm in the vehicle be it a Toyota alarm or aftermarket).
  5. aaf709
    3,862
    2022 Prius Prime
    The only theft (and probably apocryphal as I don't know the location) that I know of was someone went to a party and left their purse on a table. The thief took the fob and kept pressing the button in the parking lot until a car "answered." Even if it is aprocryphal, that's one way to steal a Prius (taking the fob). The other way is the aforementioned putting the Prius on a flatbed.
  6. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(aaf709 @ Dec 31 2006, 08:32 PM) [snapback]369165[/snapback]</div>
    Both of which are no different than any other modern car (with a remote keyless entry).
  7. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(darelldd @ Dec 31 2006, 10:19 PM) [snapback]369184[/snapback]</div>
    Right, it goes back to the thief's best plan is to take your fob, as a hotwire ain't that easy. BTW, if the thief were to pull you out of the Prius and drive away it can be done, but if they power off it won't restart (assuming you have the fob on your person when this occurs).
    There's been a rumor that the fob's signal can be emulated with a special gizmo, but I haven't heard of one being stolen with this method.
  8. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    One interesting thing that has started to happen recently is because of these immobilizer systems, thieves will break into your home and force you at gunpoint to give them the fob/key (some have the chip integrated into the key) so they can take your car. Kind of a backfire of security. Probably not for a Prius though. Not expensive enough.
    As far as the fob signal emulator, I doubt you will ever see one for a Prius. The car isn't worth enough to make it. Now a BMW, Lexus or Mercedies emulator may appear in a thiefs toolkit! I wonder how close the Lexus system is to the Prius one?
  9. Tideland Prius
    16,402
    I'm not sure. Toyota doesn't even call them by the same name so I don't know if it's a marketing term or if it really is slightly different to warrant a different name. This is different from Nissan which calls its system "Intelligent Key" regardless of whether it's on an Infiniti or a Nissan.
  10. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    <div class='quotetop'>QUOTE(David Beale @ Jan 2 2007, 01:46 AM) [snapback]369257[/snapback]</div>
    David: Folks who can afford high end cars usually park them in their garages or driveways; I park my Prius on the block behind my house because of traffic on my street, so a thief would have no way of knowing where I lived unless he could find the insurance/registration tags hidden in the car.
  11. Renocat
    Renocat Member
    363
    Rochester, NY
    <div class='quotetop'>QUOTE(Bob Allen @ Jan 4 2007, 07:24 PM) [snapback]371038[/snapback]</div>
    I bet you hid them in the hidden drawer beneath the console, didn't you lol :lol:
  12. nicoss
    nicoss New Member
    304
    I never keep any document in the car, registration & insurance are in my wallet.
    Have tweaked the glass breakage sensor so that tapping a window with a coin will trigger it.
  13. jmccord
    jmccord New Member
    199
    San Diego, CA, Earth
    Speaking of alarms...
    Is there a post on PC that explains the Prius factory alarm algorithm (how it works)? :huh:
    In other words what, and how many, series of events will activcate the alarm - door trunk latch opening prior to receiving FOB signal, etc?
    While I use the alarm and know how to activate/deactivate it (by locking/unlocking the car) that's about the extent of my knowledge.
    Forgive me if its in the manual - it's late and I'm not going outside.
  14. Tideland Prius
    16,402
    <div class='quotetop'>QUOTE(jmccord @ Jan 11 2007, 10:02 PM) [snapback]374560[/snapback]</div>
    - battery is disconnected then reconnected when the doors are locked
    - hood is forced open
    - any door is forced open
    - hatch is forced open
    - door is unlocked from the inside *Important if you lock the car with someone inside
  15. jmccord
    jmccord New Member
    199
    Thanks Tideland.
    Thats good to know.
    I guess that means there's no "motion" sensor, like some cars that alarm if either end is raised as if being towed. Still, seems like a decent alarm system. Like you say, just don't leave someone locked inside. :eek:
    What would be the best defense during attempted carjack?
    Just get away with the FOB on your person?
    Can a Prius with Nav be tracked Lo-jack style?
  16. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(nicos @ Jan 11 2007, 09:42 PM) [snapback]374555[/snapback]</div>
    Which also provides endless entertainment for kids with pea-shooters...
  17. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(jmccord @ Jan 12 2007, 10:15 PM) [snapback]375079[/snapback]</div>
    If the Prius is running and someone carjacks you, they can drive away even if you have the FOB on your person. But once it's stopped, it won't restart unless the FOB is in the Prius.
    Since the NAV system only receives, and not transmits, I don't think it can be tracked like Lo-Jack. If you want additional alarms, then the glass sensor and the motion sensor you mentioned could be added.
  18. David Beale
    5,963
    1,985
    Edmonton Alberta
    One other thing I've read about the Prius. All Prius have the alarm system "installed" (in software). If you buy the glass breakage sensor and plug it in, all that has to be done is "enabling" it in the cars system. There is no further electronics to add.
    As far as motion sensors (or even the glass breakage sensor), I've found them to be more trouble than they're worth (with other cars). People ignore car alarms anyway as there are so many falses. What's the point?
    Just make sure there is nothing "interesting" visible from the outside of the car, and most of the time you'll be ok.
    Keep the fob in your pocket (even women, not in your purse as the thief may keep that). If a carjacker wants your car, give it to him and run.
    Someone may want to check this on the Prius, but on the anti-Prius (see below) if you have the vehicle running and press "panic" on the fob nothing happens. I think that it would be a good thing if it shut off the car, so when you start running you press the button leaving the carjacker in a car with horn blaring and no go! Maybe a five second delay would be a good thing too. So you can get clear in case they are armed! (watching too many Spike police video shows). ;)
  19. fphinney
    fphinney Member
    234
    Walnut Creek CA
    <div class='quotetop'>QUOTE(Renocat @ Jan 5 2007, 06:56 AM) [snapback]371214[/snapback]</div>
    I was really disappointed to see that a Prius owner would come out & say this - Does this revelation make you feel better? Revealing secrets of others doesn't feel admirable to me -
  20. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Well, Frank, you just have to remember that Prius owners are ordinary people.
    1. We have good and bad behavior, like non-hybrid drivers;
    2. We may make wisecracks that would be OK in a conversation, but don't work in a written situation.
    3. We write things that can be easily misinterpreted, like all Internet users.
    Now, as far as the topic of carjacking goes, you're dealing with an armed robber. Give him what he wants. If he asks for the fob, hand it over. It might even be unwise to suddenly run away---you could spook the robber and be attacked.
