Any advantage to recharging 12V battery?
Discussion in 'Prius PHEV Plug-In Modifications' started by adric22, Feb 1, 2010.
  1. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    145
    Fort Worth, TX
    I was just thinking. Since I'm installing a plug-in kit in my car I will have 110V AC mains power coming into the vehicle. So it would be fairly trivial to add a small 12V trickle charger to charge up the 12V battery. I'm just not sure if there'd be any benefit. I'm not sure if the prius allows the 12V system to drop any before recharging it or if it runs the DC-DC converter 100% of the time to sort of charge it like an alternator would in a regular gas car.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It runs the DC to DC converter 100% of the time.
    Tom
  3. mrbigh
    3,686
    699
    Long Island, NY
    No benefit at all, leave the Aux battery along.
  4. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That depends on your driving habits. The charging system is a "constant voltage" system (yes it is on 100% whenever you are in "Ready" mode) which is a safe way to prevent over charging the 12v battery, but is sloooow. If you drive for long periods, this system maintains the 12v battery well (lead acid batteries should always be maintained fully charged or they suffer premature failure). If you do a lot of short trips, using a "Battery Minder" (not a trickle charger) that is set up for AGM lead acid batteries (about $60) is a good idea.
    BatteryMINDer® Plus AGM/OPTIMA Maintenance Charger / Desulfator-Conditioner 12 Volt – 1.0 Amp | All | Battery Chargers by BatteryMINDers.com
    JeffD
  5. qbee42
    18,058
    3,076
    Northern Michigan
    This advice is spot on.
    Tom
  6. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    I see a VDC 1.3 amp model #12117 at amazon for $45. On the high end, Northern Tool 2/4/8 amp for $100. I suppose the Northern might double as a charger, whereas the 1.3 requires a charger first to revive a dead battery.
    Any thoughts as to brands or features that are must have or avoid for sure?
  7. jdenenberg
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Not a Charger, but a "Battery Minder".
    The competing product line is "Battery Tender"
    Battery Tender - Home of the Battery Tender Jr. - Batterytender.com
    But the "Battery Tenders" do not have the added feature in the "Battery Minders" that prevents (and often corrects) "sulfation" (The creation of a layer of sulfur compound crystals on the surfaces of the lead plates which reduces the effective plate surface area) which is a major cause of premature lead acid battery failure.
    JeffD
  8. ksstathead
    1,244
    245
    Kansas
    Your battery minder link is the 12118 model which seems to only be for AGM-type batteries. The 12117 model says all 12-volt, including AGM-type. And the 12117 is $5 less at the VDC site. Seems odd.
    If I could get one unit (12117) for all my cars, that would make me happier than only being able to use it on the Prius... Any thoughts?
  9. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    Prius consumes approx 30mA when the system is off.
    If your Prius stayed off-position for 12 hours (overnight), it consumes 4.32 Wh of 12V electric energy.
    One gallon of gasoline has 36,370 Wh of energy, or we can pull 12,730 Wh energy by 35% Prius engine efficiency.
    If you charged the 4.32 Wh by your charger, you can save 0.00034 gallon of gasoline per night. :)
    Ken@Japan
  10. ksstathead
    1,244
    245
    Kansas
    ken1784, thanks. My concern is with making sure the battery gets an initial charge and that the 12V draw while short-trip driving (not merely while off) is accounted for to maintain its charge. Also, longer term with extending battery life via desulphation. My dog sleeps in the garage with the car, so I cannot open the gargage door and leave the car running overnight (CO). I do leave it running when I can, but it is my wife's daily driver. She would have lights, stereo, wipers, climate control, NAV, Bluetooth, cell charger, etc. going. Am I worried over nothing? Something is killing batteries early in some cases.
  11. jdenenberg
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I assume that there was a reason to raise the chaging voltage in the AGM specific model. The only drawback I see is that 12117 may result in slower AGM charging than the 12118. A call to their tech support at (800) 379-5579 Ext. 206 line may be in order.
    JeffD
    ps. My Jetta also has an AGM battery
  12. ken1784
    2,943
    1,380
    67
    Yokohama, JAPAN
    I don't know how short your wife drives, but...
    The 2010 Prius DC-DC converter has max 120A supply capability, and I think 10 minutes driving is enough to recover the 12V battery discharged for a week rest.
    Ken@Japan
  13. ksstathead
    1,244
    245
    Kansas
    But I thought it would only send 1 amp to the 12V, and only while in ready mode. Everything I've seen talks about how slow the system charges the 12V. How can it send 120A to the little 12V without overcharging?
    edit: Guess you are saying the converter supplies the load while driving, so only the tiny draw while off has to come from the 12V?
    Sorry to be a pest, but am ignorant in matters electrical...
  14. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    I agree with jdenenberg, if you have any reason to worry that your 12V acc battery is in need of assisted living, a BatteryMinder set up the way you suggest in your original post would be a nifty mod. You'll probably extend the life of that 12V battery quite a bit in the process.
    - D
  15. ken1784
    2,943
    1,380
    67
    Yokohama, JAPAN
    I believe your 1A is the 200V HV battery current to the 12V line for keeping Prius in ready mode.
    The DC-DC converter supplies a constant voltage and it keeps the 12V battery 100% charge level. It's only less than 0.1A trickle charging.
    The max 120A is going to head lamps, PTC heaters, fans and others on the 12V line.
    I think you're correct.
    Ken@Japan
