Any hybrid battery service outfit in the Bay Area, especially East Bay, recommened?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sli, Jun 10, 2024.
  1. sli
    sli Junior Member
    2006 Prius Big RTOD and Engine Check light is on, most likely hybrid battery. Any trustworthy outfit to recommend in the SF Bay Area?
    50,805
    there are a few good places out there. one is earthling automotive
  3. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    How many miles on the 2006?
    Try locating a compatible obd2 scanner and retrieve the stored codes, no sense in guessing what the problem could be.
    Does the HV battery fan near the back passenger shoulder area make more noise than usual? (tell tale sign of a failing HV battery)
    Are you looking to upgrade to a new Lithium or new OEM NiMH, or more of a swap and pray that it lasts longer than 30 ft or 30 seconds?
    How long to do want to keep the vehicle, and can you afford the down time if it fails on the way to school, doctors appointment, work, etc.
  4. sli
    sli Junior Member
    The code is P0A80, Replace Hybrid Battery Pack!
    So looking for reliable Prius battery service in the East Bay
  5. bisco
    50,805
    what type of 'reliable' service? you need a new pack. only dealers do that, or you can buy one and install it.
    there is nothing reliable about reconditioned packs.
