any incentive for plugin prius 2011 ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mk1039, Nov 13, 2010.
  1. mk1039
    mk1039 New Member
    Texas, usa
    i live in Texas, US.....will there be any incentive like Tax incentive or some thing else for the upcoming plugin prius to bring down the price ? any idea
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    The plug in Prius will not be released until around June 2012, so incentives for 2011 don't matter.
    When it is released, yes, it will be eligible for incentives like the Volt, but not as mush as the Volt. I think the Volt is something like $7500 since it has a much bigger EV battery. The Prius will probably be something like $3000. That's a guess.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    It should qualify for $2,917 to be exact if the retail version has the same battery capacity as the prototype.
  4. mk1039
    mk1039 New Member
    Texas, usa
    prius phev coming in june 2012 is too far. as of now, is there any company there that can do the conversion in DFW area?
    does converting current brand new prius to plugin zeros its warranty?
    also , other than prius, leaf and volt, any idea which other companies are working on super efficient and reasonable priced hybrid/electric cars?
  5. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Hundai?
  6. austingreen
    austingreen Senior Member
    13,623
    4,165
    Austin, TX, USA
    Yes it will void your Toyota warranty on the drive train and likely suspension. The conversions give their own warranties but I don't know if those are worth as much as a factory warranty. That and the future cars will prevent me from converting.
    Ford will be selling its BEV focus next year, but you may need to drive down to austin to get a test drive. It will have a PHEV focus in 2012. Hyundai will also have BEV and PHEVs soon.
  7. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Any incentive to buy a charging station for the Plug in Prius?
  8. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    It is not clear to me why you would buy a charging station in 2011 for a car that won't be released until mid 2012 but they start at $700 and there is a Federal Tax Credit.
    Electric Vehicle Charging Stations Products
  9. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    It only takes 3 hours To fully charge it with 110v regular plug.
  10. sub3marathonman
    sub3marathonman Active Member
    557
    75
    I haven't seen that it is a definitive "yes" that your drive train warranty is voided. Once again, it would have to be proven that the modification was the cause of the failure. Now, maybe there are cases I haven't heard about, and maybe Toyota tried to void the warranty just because a kit was installed, but I don't know if it would hold up in court.
    And I've never heard of possibly voiding any warranty on the suspension. What difference does it make if you're hauling 200 lbs of batteries or 200 lbs of sugar in the trunk for years, as long as you don't go over the GVWR there is no voiding of the warranty. And if you do go over the GVWR, you can do that with or without batteries in the trunk.
