Any way of chaning MPG to 100KM/L on dash
Discussion in 'Gen 3 Prius Fuel Economy' started by d4vit, Sep 13, 2023.
  1. d4vit
    d4vit Junior Member
    17
    GE
    Hello,
    i have Toyota Prius Gen 3
    which displays consumption data in MPG but in my country we are using metric system
    and it's annoying to converting through google everytime
    and i saw that there are also gen 3 which do calculations on metric system
    so the question is what i can do to my car to have everything in metric system ?
    changin dash? chaning firmware? any manipulations?
    50,800
    in n/a, there is a button below and to the side of the steering wheel
  3. fuzzy1
    10,332
    That switches only the speedometer between mph and kph. It doesn't change fuel consumption displays.
    PS: "Divide the MPG into 235.21. The result will be the converted number of liters per 100 km. So, 24 MPG (US) is equal to 9.8 L/100km"
    3 Ways to Convert MPG to Liters per 100km - wikiHow
    Mendel Leisk and d4vit like this.
    50,800
    thanks!
  5. Mendel Leisk
    40,231
    I cottoned onto this years back, the hard way, did the conversion step-by-step, then started distilling the process down to minimum, ended up with the above. I dropped the trailing one (just used 235.2), and it seems to still be very close.
    FWIW, I think Gen 5 will switch fuel economy units as well.
    fuzzy1 likes this.
  6. d4vit
    d4vit Junior Member
    17
    GE
    So changing only dashboard to europian version will not work?
  7. fuzzy1
    10,332
    I waited until someone else (you??) mentioned it, then independently verified it.
    But I dropped an addition digit, 3 seemed enough for my mental use.
