Anybody Alive???
Discussion in 'Diesels' started by durallymax, Nov 27, 2010.
  1. durallymax
    durallymax Member
    142
    Under The Hood
    This diesel section sure died off quick. O well I suppose it is a Prius forum.
    But there is big news ahead 1/1/11 Thats 4 ones and 4 ones that many mfgs are saying omg too. What does it mean??? Tier 4 emissions for off road engines from 150-750hp. These emissions are nearly as strict as the emissions for 2010 on road engines.
    So how are all of the MFGs meeting this?? Well most of the smart ones are using SCR and the dumb ones are using complex EGR systems, whats they difference? Ill explain because im bored. But in all reality i posted this on a diesel site a few days ago so Im not bored at the moment.
    Enjoy, im starting to miss this site.
    $7.43 per gallon is also a very high price. You wont buy it for $2.50 a gallon unless you buy a semi tanker load, but you can buy it for $3-5 all day long. I buy mine for $4 per gallon right now. Our tractor uses about a gallon every 10 hours. I get it from NAPA, Peak Blue DEF. Its the best price Ive found after looking around and it comes with a nice handy nozzle.
    Places to buy DEF include nearly every auto parts store, light duty diesel ford and gm dealers, mercedes dealers, agco/massey/fendt/challenger/case ih/new holland tractor dealerships, truck stops, and every single heavy truck dealership.
    Its becoming more and more common and pumps are being put in at many larger truck stops.
    It is important to only buy what you need as DEF has a short shelf life of 1-2 years depending on how it is stored.
    Its also important to note that it is corrosive so dont spill it on your paint, metal surfaces and especially be careful around electronics.
    It is an irritant to so if you get it on your skin rinse it off.
    Now there is big dispute over the price, people say "I can go buy fertilizer grade 32% UAN for $1-1.5 per gallon,why are they charging $3-12 per gallon for DEF?" Well my freinds that is because they are hardly the same UAN (Urea Ammonium Nitrate) is only about 16% pure urea the rest is ammonium nitrate to make up the 32% nitrogen, then the rest is water. DEF is 32.5% Pure Urea and the other 67.5% is Ultrapure Water. When you look at the facts, and the concentrations and quality standards of the two, you realize that DEF is priced fairly within the Urea Market.
    Then there is the big dispute that prices for DEF are going to soar through the roof because nearly all on-road diesels and most off-road diesels(150hp-750hp) will be using SCR systems and needing DEF.
    I dont forsee the automotive demand for Urea causing prices to go up that much, over 90% of Urea goes straight to agriculture. Automotive usage is very low.
    Furthermore, DEF price is directly related to natural gas prices since it is made from ammonia and CO2 which is mostly made from Natural Gas these days.
    I dont see the price of DEF drastically going up because more people will be using it, if anything I see the government maybe getting involve to regulate the price of it somewhat seeing as how it is required for most diesel vehicles to run, just like fuel.
    And of course at the end of all of this you can always drive a cummins. But now lets compare SCR systems to EGR systems.
    1st the basic principles, Combustion temperature is a big influence on the production of NOX gases. Hotter combustion means more NOX, cooler means less, in theory.
    EGR systems such as those used by cummins and John Deere rely on the engine itself to do all of the emissions scrubbing for NOX mostly by recirculating very large amounts of cooled EGR gases and then use the particulate filter to trap particles.
    SCR systems rely on external scrubbing for NOX and a particulate filter to trap the particles.
    So lets look at how EGR type engines try to reduce NOX. They want to reduce the combustion temperature and try to reburn some of the exhaust at the same time. To do this they lower compression ratios and add large Cooled EGR systems to the engine.
    Now how do the SCR systems do it? Simple, they just inject the DEF, let it react in its catalyst and all is good.
    So lets look at the pros and the cons of both systems.
    First the physical parts. Its kind of a draw in this section between the two.
    EGR systems are large and take up a lot of space in the engine compartment not to mention all of the valves and such.
    SCR systems leave plenty of room in the engine bay, however you do have to have a DEF tank and the catalyst which take up some extra space and add some weight.
    Now lets look at the cost of parts, everybody know EGR system components are pricey, but so are SCR system components. Case in point, I just replaced the DEF sensor in our new tractor, its a $1400 sensor. I would call this section a draw between the two systems also.
    Now lets get to Fuel efficiency, the area where SCR walks all over EGR systems.
    EGR type engines have to tune the engine for emissions before worrying too much about power and efficiency.
    SCR type engines tune for power and efficiency and let the aftertreatment systems take care of the rest.
    Case in point, 397hp Duramax and 400hp Powerstroke are both getting better mileage than the 350hp Cummins.
    Next lets look at additional costs over time. Many people bash SCR systems because you have to add DEF. Well check you service book, on EGR systems your changing the oil 1.5-3 times more often. Thats a lot of money. Not to mention the premature wear that has on the engine. Go pull the dipstick on an SCR engine, the oil is actually clean, EGR engines not so much, its nasty.
    So operating costs of an SCR system generally are lower because while you have to buy DEF, you dont have to buy as much fuel, oil and oil filters.
    Lets also look at that little guy called the DPF the gremlin everybody hates.
    EGR type engines pump tons of exhaust back into the cylinders and have low compression ratios, thus providing cooler combustions temperatures. Do you think diesel likes to burn hot or cold? Ding ding ding, hot. Weve known for years, hotter combustion, more complete burn. More complete burn means less particultes.
    So generally speaking, SCR systems will require fewer regenerations for the DPF which reduces fuel usage even further and also reduces downtime in the shop due to plugged DPFs that need to be removed and cleansed.
    Lets compare this to something other than actual engines.
    Lets say your a marathon runner, and your running in California. And since CA is literally nuts they have no imposed a restriction on emissions from your...exit area. Some genious scientist invented a device to take care of one part of the emissions (compare this to DPF) which everybody wears, then there are two other systems one that uses a chemical to reduce your emissions, and one that requires you to breath in your emissions and reuse them with your lungs doing the filtering and such, which runner would you rather be?? Poor analogy I know but you get my point I think.
    Many people also complain about the labor it takes to put in DEF. Oh my gosh you have to drive to the store, buy some and put it in the tank. You do this for your windshield washer fluid too because it keeps your windshield clean right?? Exactly. Or if its still too much work for you, you could think about laying under your truck changing your oil twice as often.
    So to summarize everything weve learned here are the pros and cons of the systems.
    SCR Cons: You have to get away from the TV and buy some DEF and put it in the tank every once and awhile.
    SCR pros: Better fuel efficiency, fewer oil changes, longer engine life, fewer DPF regens, and less junk in your engine.
    I say SCR FTW, but ill let you decide.thanks:
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    While I do think someone will make diesel hybrids, I do not think they will be start-stop hybrids, that does not play into a diesel's strengths. I am thinking the diesel will be sized small and run at almost constant RPM, and the electric motor will add acceleration and regenerative braking. Perhaps regenerating the DPF can be synchronized with braking, so the ICE can focus on the DPF.
  3. durallymax
    durallymax Member
    142
    Under The Hood
    Yes thatsa been the general consensus, that they will be constant load like locomotives. Starting and stopping a diesel doesnt work so well.
    DPF regens are completely seperated from the engine on some engines (where the engineers are smart IMO). A downstream injector injects fuel to be ignited for DPF regen.
    Now on other engines such as the 6.7L cummins the engine injects fuel on the exhaust stroke. Still basically seperate from the engine but harder on it.
    When they really need some heat created they will start to restrict the engine to make the exhaust hotter.
    DPF regens are a huge PITA as of now, but im hoping sooner or later they can get it figured out.
    But I do like your idea of having the regen when braking, and now after typing for a bit I see where you are going with it. Having it regen when slowing down, then pause when accelerating so that the engines performance is not affected by the regen.
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
  5. durallymax
    durallymax Member
    142
    Under The Hood
    nothings ever far away in Europe, theyre light years ahead of us
  6. davesrose
    davesrose Active Member
    767
    164
    Atlanta
    Nor in the States. People forget that the diesel market in the States is with trucks: commercial or residential. I've noticed some articles on hybrid semis for some years, but looks like both Dodge and Ford have been developing diesel hybrid pickups:
    Diesel Hybrid Truck: Which One is the Best? - CarsDirect.com
    2011 Dodge 1500 Hybrid
    Mitsubishi Releases Diesel Hybrid Truck in Japan : TreeHugger
  7. guinness_fr
    guinness_fr Junior Member
    68
    france
    Thanks for your post which reminded me why I ran away from the diesel technology for my every day car and opted for the HSD instead.
    While diesel engines are perfect for some applications, we should keep them out of cities.
  8. durallymax
    durallymax Member
    142
    Under The Hood
    What is your reasoning behind that?
  9. guinness_fr
    68
    france
    I live in a country where diesel is almost 15% cheaper than gas. Combined with the apparition of common-rail diesel engines, this led to having 70% of personal cars in France being diesel engines, including small city cars in the past few years.
    A study by ADEME (French scientists hired by the govnmt) revealed that diesel particulates and NOx levels were responsible of thousands of death among the aged population and tens of thousand of respiratory diseases among children (NOx being heavier than air it tends to accumulate at the level where children breath).
    If you add to that the noise level of all the diesel engines in a traffic jam (you should compare a traffic jam in NYC and one in Paris :eek: you'll hear what I mean), then to me diesel engines have nothing to do in highly populated cities.
    Fortunately the trend of dieselisation is diminisihing, at least on small city cars: Nissan for instance no longer offers a diesel engine for its Micra.
    My previous car was a diesel HDI, I'm much happier with my Prius now.
    Diesel are great for people who drive mostly highways though.
    PS: About the ways to try and make diesels clean, I've seen first-hand what happens: when the vehicle ages, people no longer maintain them (I've seen people block their EGR valves shut to avoid dealing with its problems), so that we end up with a nasty diesel!!
  10. durallymax
    durallymax Member
    142
    Under The Hood
    oops I always forget about people being in different countries.
    Old diesels were noisy and polluted a lot. Now they are quiet and Clean (at least across the pond). The New LML Duramax is queiter than its gas engine counterpart, same goes for the new 6.7L Powerstroke, you cant hear them running anymore than a gas engine and under acceleration, the diesels are actually queiter than the gas engines.
    As for people who are too lazy to maintain there emissions systems, try doing that on a new diesel with SCR. It wont run and if it does it will be very limited on power. All of them have failsafes so that if the emissions equipment goes bad, the equipment has to be repaired or the person who bought a 400hp diesel will be driving a 100hp diesel until they can fix it.
    The new diesels are damn clean, we have one on our farm. The tractors exhaust is very clean but the smell it gives off from burning the urea is interesting.
    But I understand all of your points you make. They make sense. I just like to play devils advocate because many people still have the stereotype that diesels are dirty, noisy and slow.
  11. 02semiata
    02semiata New Member
    16
    New York
    I would go diesel if the price of diesel was the same as gas. I love the TDI
  12. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Diesel has its usage and the idea of a diesel hybrid is interesting, esp with the engine running at a constant speed as this will help with emissions.
    However, diesel for car use is a thing of the past, despite some merits.
    Over here in Europe we've been told for decades how good diesel is and how efficient, clean and quiet the 'modern' diesel car is. However, there are lots of negatives to diesel use as the previous French poster has touched on. A new well maintained diesel is clean and quiet - add a few years and tens of thousands of miles on it and you will find problems occur.
    I believe European car manufacturers and governments have a vested interest in diesel sales but the negatives of significant diesel use are now outweighing the original benefits. In the US you might have a market for diesel SUVs though and not just on the massive ones, but even the smaller (by US standards) ones such as Range Rovers and Grand Cherokees etc, but it's probably best avoided in cars.
  13. wxman
    wxman Active Member
    632
    227
    Tennessee
    @ GrumpyCabbie,
    Are you aware that the EU is about to set a particle number (PN) emission limit on gasoline vehicles? According to the California Air Resources Board, CARB, if the limit is set the same as it currently is for diesel vehicles (as of EURO 5 - 6X10**11 particles/km), gasoline vehicles will require particle filters to meet the standard. If that does indeed happen (and I see no reason why gasoline vehicles should be given a break wrt PN emissions), gasoline will become less viable also.
    Furthermore, poorly maintained gasoline vehicles are no bargain for air quality either, so that can go both ways.
  14. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    I saw diesel price today in NJ $9.99 per gal. :eek::eek::eek:
  15. durallymax
    durallymax Member
    142
    Under The Hood
    Exactly.
    But with diesels the emissions treatment comes after the engine itself, so if the engine isnt maintained, the emissions systems will still take out the particles and such. And if the emissions equipment isnt maintained, the engine goes into reduced power limp home mode. Dont know many gas engines that do that.
  16. guinness_fr
    68
    france
    Please note that durallymax is talking about specific engines (over 6L) for heavy duty vehicles, I'm talking about much smaller engines that are everywhere around us here in Europe. On the engines in our streets, I can assure you that Particulate filters do not hold well over time (plus they need to burn stuff and expel al the particulates every once in a while :eek:) and diesel that reduce NOx are almost non-existent in our streets.
  17. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    There's also the point that they're discussing the theory or experience of a handful (compared to Europe) of vehicles whereas we're discussing the facts. We both live in countries where more than half the cars on the road are diesels and we both experience the negative effects from this. It isn't just old diesels, modern well maintained almost new Audi's or BMW's can be kicking out the most unpleasant amounts of smoke when taking off from the lights.
    But hey what do we know. We might not be technically qualified but we know a smokey diesel when we see it - and we see lots of them.
  18. wxman
    wxman Active Member
    632
    227
    Tennessee
    Perhaps early DPFs were subject to high failure rates, but as far as I know, light-duty diesel vehicles currently can't be certified (in either North America or Europe) without DPF as part of the emission control equipment. At the very least, they have to be warranted for the "full useful life" (FUL) of the vehicle (120K miles in NA, 160K kilometers in Europe). Over-the-road diesel trucks in the U.S. have required DPFs since January 2007, and they have to be certified for a FUL of 435,000 miles. I'm not aware of any significant problems with DPFs on large trucks, and I'm sure some of the early DPF-equipped trucks are approaching, if not exceeding, that milestone.
    A study conducted by TOYOTA demonstrated that DPF actually becomes more effective in trapping particles as they age. That was recently confirmed by another independent study (Kittleson).
    DPF regeneration does temporarily increase PM emissions, but only to about what modern gasoline vehicles routinely emit. In my diesel vehicle, regen occurs about every 700 miles for about 20 minutes, i.e., just a fraction of the driving time.
    It's perplexing that you seem to be terrified of visible diesel emissions, but are apparently unconcerned about PM emissions from gasoline vehicles. :confused:
  19. wxman
    wxman Active Member
    632
    227
    Tennessee
    I have a BMW 335d complete with DPF and urea-SCR. I have never been able to produce ANY "smoke" from the car no matter hard hard I've "gotten on it". As a matter of fact, the inside of the tailpipes are nearly as clean as they were when I first took delivery of it with 3 miles on the odometer nearly a year ago.
    And according to Wayne Gerdes, administration of "cleanmpg.com", in testing conducted by Argonne National Laboratory (ANL) of a 2009 U.S.-spec VW Jetta TDI, PM and NOx emissions were near the detection limits of the most sensitive instrumentation currently available, i.e., the Jetta TDI was emitting essentially 0 PM and 0 NOx.
    Objections to light-duty diesel vehicles on emissions grounds are really no longer valid.
  20. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    It's not ALL BMWs or Audi's and I'm not picking on any particular manufacturer. Maybe it's the different type of driving situations over in Europe? I do not know. Is most driving in the US made up of long journeys on a highway? Here in Europe the problems occur in heavy traffic in small windy streets such as in the UK and France. Infact some manufacturers are now not recommending diesel cars if you travel mainly in town due to dpf issues.
