Anybody know how to have power outlets on all of the time.
Discussion in 'Prius c Accessories and Modifications' started by mpgc, Dec 31, 2012.
  1. mpgc
    mpgc New Member
    Long Beach, CA
    I have done this to my Tundra.
    There is a relay that you can pop the top off of and put a piece of paper between the contacts and then the power will stay on when the car is off. Comes in handy when your cell phone goes down and you don't want to have the car on.
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Stay in READY, that way you will not drain the tiny 12 volt battery and discover how hard it is to charge.
    sfv41901 likes this.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'm with Jimbo.......unlike ur Tundra, the Prius has a very small accessory battery that will drain very quickly.
  4. ursle
    ursle Gas miser
    1,049
    192
    NH
    Don't ignore this advice, the 12v will die fast, conduction is also a drain
  5. mpgc
    mpgc New Member
    Long Beach, CA
    Thanks all for the input.
  6. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Just think of jumper cables accidentally touching those metal bars.
  7. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    *sniff *sniff
    Smell that? crispC
  8. RRxing
    RRxing Senior Member
    2,528
    1,803
    NEPA
    Just curious, the "c" doesn't have jump points under the hood?
  9. TrafficMPG
    TrafficMPG Junior Member
    Nope. And to boot, the picture above has the seat removed. It is tight but doable. Would have been better if the battery could be located on the left hand side of the car as well. That way you could jump the car from the street side for us left side drivers.
    At least the car doesn't need much power to jump it. You could do it with a 12v flashlight.
  10. wigmann
    wigmann Junior Member
    42
    Deerfield Beach FL
    2015 Prius c
    Yes it does. At least my 2015 does
  11. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    while on the topic, would one of those handheld jump units work on the C/Prius?
  12. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    Those units should work thinking most units sold can Jump a car up to a 2.0 litter engine.
  13. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    A jump unit with cables would. a jump unit that plugs into the lighter won't as the power outlets aren't on to use or add power.
  14. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    I have a two outlet cigarette lighter box with USB ports mounted to the plastic panel of the seats right in front of the battery. The power wire goes from the battery + via an inline fuse holder to a switch mounted right next to the device. This provides 12v power all the time when that switch is on. I use it to charge my phone while the car is parked, and I also leave my tablet plugged into it constantly to keep it at 100%. Despite the tiny 12v battery size- I have never seen it get drained. That's because I pay attention to it, and I know that you can't draw too much without the car in READY mode.
    Bigboi likes this.
  15. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    Oh man can you post some pics of what this looks like? And maybe link the 2 port cig lighter box too? One day when I make more friends or i become an Uber driver, my passengers can charge their devices in the back. Thank you!
