Anyone know why my high beams work but my low beams dont?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by RayLepson, Feb 24, 2025.
  1. RayLepson
    RayLepson New Member
    Maryland
    Both low beams won't come on. I checked the fuse for the low beams, but the fuse looks ok. Not sure where to go from here. Any help would be appreciated. Thanks.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,285
    5,656
    Texas Hill Country
    odds are good both low beams are burned out.
    Merkey, Mendel Leisk and Brian1954 like this.
  3. ChapmanF
    16,940
    Where did you find a fuse for the low beams? I think of v and gen 3 liftback being similar, and gen 3 doesn't have one, but maybe v does.
    Gen 3 liftback has a long white 'integration relay' that powers both low beams and a bunch of other things, and one 40 amp fuse on the supply to that. If that one fuse went open, a bunch of things would stop working.
  4. rjparker
    9,285
    5,656
    Texas Hill Country
    Chapman is right, the low beams are just a 40 amp as shown below
    Each low beam has a separate ground so grounding problems are unlikely.
    The high beams have their own fuses but in your case they are good.
    What does happen is one low beam bulb burns out (H11 type) but it goes unnoticed until the other fails.
    ETC(SS), Merkey and Brian1954 like this.
  5. RayLepson
    Maryland
    Because both were out, I didn't consider that a possibility. I'll get a couple new bulbs and try it. Thanks!
  6. RayLepson
    Maryland
    RJParker, I'll go with the new bulbs and see how that goes.
    The fuse for the low beams is, I believe fuse 20. It is clustered with two other fuses. All were in good condition.
    Thanks to everyone who replied. I appreciate it!
  7. MAX2
    MAX2 Senior Member
    1,333
    415
    101
    Third planet from the Sun
    It remains to be seen whether the car has a DRL module or not. If the module is faulty, then voltage will not reach the lamps.
  8. Brian1954
    Brian1954 Senior Member
    1,562
    606
    South Central PA, USA
    The OP's profile lists his location as the state of Maryland, which is in the USA. The USA version of the Prius does not have DRL.
    Air_Boss likes this.
  9. ChapmanF
    16,940
    The picture rjparker posted shows the 40 amp P/I 2 fuse that supplies power to the integration relay. That fuse is indeed a three-fer, combined with two brake pump fuses.
    What rjparker's picture doesn't show—because this, like it or not, is how Toyota does their diagrams—is everything else that comes out of the integration relay. If you look at the headlights diagram, it just shows you the P/I 2 fuse, and the integration relay, and the headlights. If you look at the horn diagram, you see the P/I 2 fuse, and the integration relay, and the horns. If you look at the defogger diagram, you just see the P/I 2 fuse, and the integration relay, and the defoggers. And so on for everything else the integration relay supplies.
    You can't just easily flip to one diagram that shows you all the things supplied by the integration relay. But you can be sure they will all not work if that P/I 2 fuse opens.
    RayLepson, MAX2 and Air_Boss like this.
  10. RayLepson
    Maryland
    Brian1954 likes this.
  11. rjparker
    9,285
    5,656
    Texas Hill Country
    It's happened to many people.
    RayLepson likes this.
  12. ETC(SS)
    6,841
  13. Merkey
    Merkey Active Member
    290
    264
    Birmingham, Michigan
    Too bad Toyota didn't make the passenger side bulb as easy to access as the driver side bulb.
