Anyone live in the country and drive a prius?
Discussion in 'Newbie Forum' started by triton77, Jan 6, 2017.
  1. triton77
    triton77 New Member
    WI
    Newbie here needing advice on possible prius purchase.
    Would you buy a prius if you lived 15min from the closest town and 1hr from the closest Toyota dealer?
    We are in WI too so add: snow, ice, and days of below zero temps. Also we have a 1/2mi long gravel driveway.
    The car would be driven daily but only for about 15min total running my kids back and forth to school. It would be used on longer trips like once a month to run errands.
    We live on and run a pasture based farm so most weeks I don't leave the farm except to take my kids to and from school(sounds exciting doesn't it ;) ).
    We keep our cars until the die, our newest car is a 2008 tundra with about 70k miles.
    My husband thinks a hybrid isn't a great choice for where we live and how we drive. I want a hatchback car with good gas mileage.
    Any thoughts or suggestions?
    Thanks
    Janelle
    Burna J likes this.
  2. Tideland Prius
    16,403
    15 mins... that's what, 6 miles? You're better off with an electric car or a plug-in hybrid like the Prius Prime or Chevrolet Volt.
    However, if you prefer a hybrid. It will work as well as any car. Note that the 2016 and newer Prius do have a lower ground clearance than before (about 0.5" lower... to about 4.7") so it may scrap the snow/ice if the driveway isn't cleared. Heater performance is adequate but an engine block heater will do wonders for mpg and heat (it's more efficient to use a block heater to pre-warm the engine. It allows the engine to warm up faster, thus giving you heat more quickly, as well as taking advantage of the Prius' engine-off ability. If the engine is cold, the Prius will continue to idle the engine to get it up to operating temperature to reduce emissions).
    Also, hybrids are used as taxis in the Arctic Circle. There was this Highlander Hybrid, two Camry Hybrids and a Prius v in Inuvik, Canada. The nearest Toyota dealership is 766 miles (1,226km) away!
    RCO likes this.
  3. 2010pri
    2010pri New Member
    Quincy Ca
    We live right outside a town of less than 5000 in a county with 7 people per square mile or 21000 people total. We have about a mile of dirt road between us and town. My wife uses ours to work in town and haul child to school replaced a Subaru. We put snow tires on it and were happy on icey roads it's low and can't wade through snow though at all. Were 3 hours round trip to any small city and it changes the dynamics if we feel like going for lunch and a movie we'll go much easier as the commute is less than half the cost our diesel pickup. The idea of getting where we need to go and spending less to get there isn't getting old. Might be able to put off the day you have to replace your Tundra wow trucks are getting expensive. There's a lot of Prius's around our area but we are in California that's probably the difference.
    RCO likes this.
  4. jcaprani
    jcaprani Junior Member
    Fiji
    #4 jcaprani, Jan 7, 2017
    Dale Denton and RCO like this.
  5. bisco
    50,814
    welcome!
    an hour from the closest dealer if no other service available and you don't diy might be an issue.
    i've read that gravel can be a problem, but no personal experience.
  6. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    660
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    My wife used to have a rural mail route in the country. We also live in the "boonies" and about 1/2 hr from the nearest Toyota dealer. At the end of '07 we bought a new Prius just for her route. That job beat the crap out of every car we had for that job, and I have to say, the Prius was the most durable car for the job, gravel roads, winter snow and the 300+ stops a day, 6 days a week for 7 yrs. 140K later we retired and still have the '08, and just bought a new v ('16), We trust it the most of any car we ever had. True, it's no rocket, or AWD off roader, but it's seen it's share of gravel and snow, she always felt safe.
    I think it would be a great choice, assuming the drive way gets plowed when there is 6" + of snow, but in reality, that happens only a few times a year.
    #6 bat4255, Jan 7, 2017
    RCO likes this.
  7. Steve Lees
    Steve Lees Junior Member
    23
    Southeast PA
    I live in farm country with a mix of gravel and paved roads. No problems so far. It can be awhile before the roads are plowed. If it snows more than a couple of inches, I leave the Prius at home and drive my 4wd F250 instead.
    RCO likes this.
  8. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,147
    1,665
    Iowa
    Live in Oregon Coast Range of mountain. Car is worthless in snow/ice as once it begins to lose traction, it wants to shut down -- I think they took out that feature in later models.
    Also, 1/4 mile drive that goes up almost 500-feet in elevation. If I have to stop on the way up (gravel road), I sometimes have trouble getting going again. Oh, the defrost function has always been less than adequate. In our Camry, foggy inside windows clear in seconds. With the Prius, it can be a real test of patience.
    RCO likes this.
  9. ETC(SS)
    6,841
    Greetings and welcome aboard!
    The only real problem you're going to have with a later model Prius in a place like the Badger state is with ground clearance.
    Snow and ice aren't much of a hurtle if you presently drive a front wheel car, and many, many people drive Priuses up there and buy a set of Corolla rims for their snow tires if they use them.
    However (comma!) you're going to have to carefully consider how much snow accumulation you usualy get for your area because if you've ever seen the underneath side of a Prius, it looks amazingly like the underneath side of a skateboard......flat underneath with itty-bitty tires.
    Get enough snow?
    They tend to DRIVE like a snowboard!! :eek:
    IF the snow gets deep enough then your car will start to behave like one of those air hockey pucks....either that or you'll hear the ZZZZzzzzzhhht!! sound of tires trying to get traction on air.
    By the way.......The same goes for mud and gravel during the three or four weeks out of the year when it's NOT below freezing.
    As far as the distance from the dealer being a problem, I think that it's a feature rather than a fault.
    All of the filters and fluids that are needed for normal maintenance can be bought on line or at a brick and mortar place during your semi-occasional sojourns to civilization....if you insist on burning cash instead of seasoned oak.
    Besides.....it would be a great incentive to watch some YouTube videos and buy $100 worth of tools and declare your independence from a lifetime of subjugation by dealer mechanics.
    If not?
    The Prius requires light maintenance and then usually every 5,000 miles.....with 10,000 mile oil change intervals.
    That's 3-4 (or 5-6) months worth of driving for the average human, and I suspect that you get into town AT LEAST that often.
    I'd rather get a colonoscopy without anesthesia than buy a Toyota from my nearest dealer.....and they're about 40 minutes away.
    Best of luck!
    #9 ETC(SS), Jan 9, 2017
