Apparent Recall 11/04
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Nov 18, 2004.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    This Link is a Babelfish translation of the Japanese announcement of a recall of many Toyota Vehicles that seems to include the Prius (NWH20 is a code for the Prius).
    Here's the translation:
    "1. Circumstance of trouble
    (1) Because form of the contact point section for the electric load
    which works in the contact point of the switch for the brake lamp is
    inadequate, oxide is formed by the contact point and there are some
    which contact resistance increases. Because of that, the switch
    becomes continuity defective, there is a possibility the brake lamp
    stopping lighting up.
    (2) Because removal of the foreign material is insufficient when
    producing the electromotive type fuel pump, wiring coating of the
    internal motor being damaged by the foreign material, it shorts, the
    fuse of the fuel pump circuit is cut off, there are times when the
    motor brush wears abnormally. Because of that, the fuel pump stops
    operating, there is a possibility the engine not be able to restart
    stopping and becoming.
    2. Contents of improvement
    (1) all vehicle and the particular switch are exchanged with the
    measure item.
    (2) all vehicle and the particular fuel pump are exchanged with the
    non-defective item.
    VIN: NHW20-0001006 - NHW20-0086574
    Productin Date: 2003 May 28th - 2004 June 11th"
    And a Dow Jones Newswire Report:
    Toyota, Isuzu Combined Recall Over 500,000 Vehicles-Kyodo (DJN)
    NEW YORK (Dow Jones)--Toyota Motor Corp. ™ is recalling a total of
    544,172 vehicles in 12 models, including the Prius and the Vitz, for
    replacement of defective parts, Japan's transport ministry said Thursday,
    Kyodo News Service reports.
    The brake lights in the vehicles, manufactured between January 1999 and
    August this year, could fail to work due to faulty switches, the biggest
    Japanese automaker said in a report to Japan's Ministry of Land,
    Infrastructure and Transport.
    The vehicles could also fail to operate as a result of defective fuel
    pumps, Kyodo said.
    The 12 models include the Corolla Fielder, the Raum, the Estima Hybrid and
    the Harrier as well.
    Isuzu Motors Ltd. (7202.TO) also notified the ministry the same day that
    it will recall 2,335 of its Forward trucks for replacement of defective
    front hub bearings which could make the vehicles unworkable due to
    overheating or cause fire, Kyodo reports.
    The trucks were made between August 2000 and May this year, but the
    defective parts were supplied by Mitsubishi Fuso Truck & Bus Corp. (MTA.XX)
    which has been involved in a series of defect coverups.
    Isuzu is also recalling 328 Giga trucks to replace faulty hydraulic pipes
    in the power steering mechanism to prevent fire. The trucks were
    manufactured between September and early November this year, Kyodo said.
    (END) Dow Jones Newswires
    Doesn't sound too serious, but it does sound like the parts manufacturer is going to be in some serious trouble!
  2. techogurl
    techogurl New Member
    226
    Fayetteville, AR
    What is the likelyhood that this will affect US owners?
  3. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(techogurl\";p=\"51326)</div>
    Very high...same parts, same problems, same VIN numbers...and now we all know!! :wink:
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Hmmm the Babelfish translation said cars through June 11, 2004 but the Dow said through August. Guess I'll have to wait for a recall letter as mine was made in August.
    Thanks for the heads up Evan
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Boy, this is becoming a long list for a Toyota based car. Is it new technology design flaws, or are Toyota's parts vendors declining in quality?
    I'm only glad that they're finding and rectifying these issues before they become wide-spread and appreciate Toyota's willingness for proactivity.
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(bruceha_2000\";p=\"51340)</div>
    The "through June 11" is for Prius and Dow's "through August" is for all models.
    Please note that the lower 7 digits of VIN is common worldwide.
    My record of total Prius sales until the end of June was 83,051 in Japan plus in the US.
    Regards,
    Ken@Japan
  8. ken1784
    2,943
    1,380
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(efusco\";p=\"51324)</div>
    Please be informed that this (2) fuel pump exchange does NOT affect Prius.
    Regards,
    Ken@Japan
