Are all 2010 Prius the same?
Discussion in 'Gen 3 Prius Technical Discussion' started by GrumpyCabbie, Mar 23, 2010.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Do all 2010 Prius's worldwide have the same emissions?
    Obviously there are differences (RHD, spec levels etc) but are the emission levels the same? Is my UK spec as 'clean' as a Prius sold in California?
    I know California requires better warranties and there are different emission levels compared to other States in the USA, but is the 2010 Prius sold in Europe as clean as the one sold in California?
    If not, why not?
    I ask because California is more concerned about smog levels than our European governments are.
  2. dogfriend
    7,512
    1,188
    Carmichael, CA
    The reason for the better warranty in California is that they must offer the warranty to qualify as a PZEV (Partial Zero Emissions Vehicle). There is a lot of history, but in a nutshell, the PZEV cars are a compromise that CARB (California Air Resources Board) and the auto manufacturers agreed to so that CARB would drop the Zero Emission Vehicle requirement in California. They are allowed to sell PZEVs instead of true ZEVs. [ame="http://en.wikipedia.org/wiki/PZEV"]Partial zero-emissions vehicle - Wikipedia, the free encyclopedia[/ame]
    I know with the Gen 2 Prius, there is no physical difference between a California car and a US non-California car; I would expect that the 2010 is the same but I don't have any tech info for the 2010.
  3. linuxpenguin
    linuxpenguin Active Member
    352
    182
    The only thing I could think of would be the minimum speed restrictions for EV mode. On the Gen2 Prius, if you exit EV mode under load (that is, you go too fast or press the pedal too hard) you end up increasing regulated emissions by 10-12 times what it would be otherwise (far exceeding SULEV emissions standards). This is of course because the catalytic converter is cold and doesn't operate well until it is warm--when you start the car normally it goes through a controlled warmup sequence that super-heats the catalytic converter to spend as little time as possible in this non-efficient zone while using the electric motors to drive the vehicle for the first 30 seconds or so. Exitting EV mode due to high speed or heavy pedal skips this warmup stage and goes straight to providing power, hence the huge spike in emissions.
    I know the US 2010 Prius has a limit of around 11 mph for EV without warming up the gasoline engine / catalytic converter first--I believe the Asian model has a limit closer to 30 mph. I'm not aware of any laboratory studies on the 2010 Prius yet so it's hard to say if this would be a factor. I would guestimate that you'd get slightly higher emissions on non-US models because of the higher freedom for un-warmed EV (everyone exits EV mode unintentionally sometime...).
    EDIT:
    Oh, I should add--a lot of countries don't have as strict emissions regulations as the US so that is likely why the EV mode is more liberal in the non-US model. It's probably also why the US version of the Gen2 didn't have a stock EV button installed.
    Andrew
  4. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Ah, this explains why the car seems to 'stumble' when you move from EV mode to engine by hard acceleration but it doesnt when it transitions to the engine normally.
    Is it almost like bump starting an old manual transmission car but a downside is that it floods the cat with unburnt fuel, hence kicking out higher emissions?
    So using EV mode in a sloppy way can actually increase tailpipe emissions considerably?
  5. Tideland Prius
    16,402
    and also increase fuel consumption (by draining the battery unnecessarily).
    I would guess that 17" alloys would increase fuel consumption very very slightly and thus increase emissions very very slightly (89-92g/km of CO2 is what you guys measure. It reads the same over here since we don't measure one particular GHG but rather the overall emissions)
  6. linuxpenguin
    352
    182
    Correct--though probably not as much as in the Gen2 as I believe the Gen3 warms up faster and it has a lower EV mode speed limit making it harder to abuse (in the US anyway).
    It's all about getting the catalytic converter warmed up first. Once it's warm--the Prius hardly emits any regulated emissions (hence the partial-zero emissions rating). It's very low emissions once it's warmed properly--which is why it's /much/ better to have multiple engine starts with a warm catalytic converter than it is to have one "dirty" start where you bypass warmup mode.
    I always say that in the Gen2 one "dirty" start produces the same regulated emissions as a weeks worth of normal driving. Not sure how true this is in the Gen3 since it's a different engine but I can't imagine it's much better. We'll have to wait for laboratory testing on the Gen3 to determine that.
    Andrew
  7. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    From Linuxpenguin:
    "It's all about getting the catalytic converter warmed up first. Once it's warm--the Prius hardly emits any regulated emissions (hence the partial-zero emissions rating). It's very low emissions once it's warmed properly--which is why it's /much/ better to have multiple engine starts with a warm catalytic converter than it is to have one "dirty" start where you bypass warmup mode."
    Remember, CO2 is now also a "regulated emission". But we understand your meaning anyway. ;)
  8. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    OK, so how come the Prius is 'cleaner' than normal cars (excluding CO2)? Does it burn the fuel more fully or is the cat much better than a standard 2010 normal car? I'm sure I've heard it said that the 2010 Prius is 70% cleaner than a normal car. Is that cleaner refering to smog/soot/pm10's or CO2?
    I'm trying to place together a small report for my local taxi authority on the emission benefits of a Prius (mine :) ) over a standard 4 pot UK petrol or diesel car/taxi.
    Just wanted to get my facts rights first.
  9. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Come on, anybody? Surely someone on here has an idea? How do the emissions of the Prius compare? Are they significantly below the legal level whereas some new cars just scrape through?
  10. Arnold
    Arnold +AT+SR
    55
    Gouda
    There are several threads about this subject, which you could Search:). CO2 emission is directly related to fuel consumption, so you already know that the Prius scores very well here. Then there are CO, NOx, HC emissions.
  11. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    "partial zero emissions". Now there is a PC gibberish term if I ever heard one. My wife tells me I need to lose a few pounds. I'm going to tell her I'm "Partially in awesome shape"
  12. Squirrel
    Squirrel New Member
    Fuerstenfeldbruck, Germany
    If you like to visit the German Toyota website you may find a brochure that claims on page 8 that NOX emissions are less than 1/10th of the EURO 5 limits.
  13. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Is that the term the EPA is using to declare that EV's will not be identified as ZEV?
    The EPA ruling brings up a whole host of questions .... will there be variances for different states? In select areas of wyoming, so much power is wind generated .... pretty clean. In Utah, it is coal generated ... How about nuclear power? hydro?, natural gas? I suspect this is a case where one rating does not fit all situations. It could get down to specific communitieswithin a state. One (or more) writers to PC plan to charge their EV with solar.
    It makes me think about trying to fill out the 2010 Federal Income Tax form ... if you live in Louisiana, there are certain credits and exclusions, in the Dakota's, there are others. No telling what else that has not been revealed to date.
  14. dogfriend
    7,512
    1,188
    Carmichael, CA
    From the link I posted earlier:
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    This is the sort of thing I'm after. I guess the US and European emissions rules are so different that a like for like comparison is almost impossible.
    Smog emissions are not really news here as they are in the US so the figures on these are hard to come by. CO2 on the other hand is quite easy to compare.
  16. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    :D
    (wonderful post, honestly - I love the "Partially in awesome shape" comment - great!)
  17. pakitt
    2,173
    1,313
    Colorado
    I have looked in the Toyota.de website but could not find the brochure mentioned by Squirrel - I have read it too someplace but cannot find it anymore.
    I believe the Prius manages to consume so much less than other cars and pollute (accordingly) so for the following reasons, compared to other cars:
    1) uses electric engine to start moving the car --> ICE is used way more often in high efficiency rpms (if not always thanks also to the CVT like transmission and the buffering action of the MG1 and MG2)
    2) much refined aerodynamics (this plays a role at x km/h, where is has to be somewhere beyond 40-50km/h - I don't expect aerodynamics to play any role at city driving speeds)
    3) the ICE is started with fuel only after it is already being moved by the MG at about (I believe to have read it somewhere here in PC) 1000rpms (ie. no fuel is injected/wasted before that - I believe cars get fuel injected also when the engine is not running by itself yet, when the starter is trying to start it - can somebody correct me here?)
    4) the ICE uses an Atkison cycle - which is by definition more efficient and less fuel consuming (but providing less power) ([ame=http://en.wikipedia.org/wiki/Atkinson_cycle]Atkinson cycle - Wikipedia, the free encyclopedia[/ame])
    Hope the comments above will help you with your report.
    89g/km is not the actual value the ICE emits, but the average of ICE emitting, say over 5km test track, 110-120g/km and 0g/km.
    Actually it would be very interesting to know what the CO2 emissions of the engine itself would be when running like a normal car (ie with no assistance of the MG at all). 110? 120? 150g/km? how CO2 efficient is the ICE and what is the FE of the ICE if it where not assisted by all the electrical drivetrain?
  18. bwilson4web
    15,933
    It may take a little work but here is a root page for the California Air Resources Board executive orders that document their testing:
    On-Road New Vehicle & Engine Certification Program
    GOOD LUCK!
