Are ultracapacitors the key to making hybrids king of the auto market?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by zenMachine, Aug 29, 2007.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    ...Toyota and its Earth-loving ilk may yet have the last laugh as they cultivate encouraging new advances in ultracapacitor technology that promise to one day put hybrids in the driver's seat.
    The greatest victory so far for the cars, fueled by a combo of electricity and gas, came just weeks ago when an ultracapacitor-equipped Toyota Supra HV-R coupe became the first hybrid to win the 24-hour endurance car race held at Japan's Tokachi International Speedway. The hybrid Supra finished 616 laps of the 5.1-kilometer (roughly threemile) course—19 more laps than the second-place nonhybrid Nissan Fairlady Z...
    The Dark Horse in the Race to Power Hybrid Cars
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    Interesting. Maybe Toyota will skip Lithium Ion all together and go straight to capacitors.
  3. jk450
    jk450 New Member
    <div class='quotetop'>QUOTE(zenMachine @ Aug 29 2007, 01:01 AM) [snapback]503636[/snapback]</div>
    The Supra uses supercaps because of its requirements and abilities on that particular track: fast power dump, followed by aggressive regen. No battery (with similar storage capacity) can approach the throughput of a supercap, but supercaps don't do so well in the ratio of power to weight or volume to weight. However, some modeling exercises indicate that a supercap array of less than a tenth the storage of a battery could engender superior fuel economy. Cost is also a problem. Race cars don't have that problem.
    Hint: Consider a small supercap array in parallel with a Li-ion pack...
  4. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
  5. zenMachine
    3,355
    300
    <div class='quotetop'>QUOTE(jk450 @ Aug 29 2007, 12:46 AM) [snapback]503652[/snapback]</div>
    i.e. a "hybrid" hybrid car
  6. Wiyosaya
    Wiyosaya Member
    298
    2024 Prius Prime
    XSE
  7. alexstarfire
    alexstarfire New Member
    220
    I don't believe that the capacitors they used on the light rail cars in Sacramento are super caps. They just said that were "large capacitors."
    The power to weight and volume to weight ratios should be addressed soon enough. Not sure if they did it with the Supra, but the caps are supposed to start using carbon nanotubes to exponential increase it's capacity without hindering it's ability to nearly instantly recharge.
  8. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(zenMachine @ Aug 29 2007, 10:01 AM) [snapback]503754[/snapback]</div>
    Some call that a "trybrid". But it definitely makes sense, especially if raw materials for advanced batteries (NiMH or Lithium Ion) becomes more expensive, as some have predicted. An ultracap could be thought of as a turbo-booster for your regular hybrid.
    I just got pulled into this thread by the phrase "Earth-loving ilk". If that's the kind of ilk I am, I guess that's not too bad.
  9. fan-atic
    fan-atic New Member
    59
    Holliston, MA
    Your Prius already uses Supercaps from Maxwell for it's regenerative braking. The battery can't absorb energy fast enough during braking so they use ultracaps. So in a sense the Prius already has ultracaps in parallel with batteries, although the voltages probably aren't the same.
  10. tochatihu
    tochatihu Senior Member
    9,456
    3,654
    Kunming Yunnan China
    2001 Prius
    fan-atic, my understanding is that those capacitors only participate in brake system control (hydraulic valves and such) if the Prius 12 volt system fails. All other times, they just sit there.
  11. fan-atic
    fan-atic New Member
    59
    Holliston, MA
    <div class='quotetop'>QUOTE(tochatihu @ Aug 29 2007, 09:23 PM) [snapback]504100[/snapback]</div>
    You are probably right. I know that the braking system needs a fallback in case of an accident, and I know that the 200 volt battery is disconnected as soon as the airbag sensor reports a collision. I guess I just assumed the caps did more than that.
  12. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(Godiva @ Aug 28 2007, 10:15 PM) [snapback]503640[/snapback]</div>
    I'm inclined to think that ultra-caps will be the way of the future. But I doubt they'll be available soon enough for Toyota to bypass lithium. Just as the Prius is a baby step toward PHEV, which itself will be a step toward 100% electric transportation, lithium will probably be needed for a while before ultra-caps are ready for market.
    I'd love to have my Xebra run on ultra-caps, but even lithium would be wonderful. With lithium batteries in my Xebra I'd never have to drive the Prius except for extended road trips.
