At over 500,000 I’ve replaced the big things though for $300 instead of OEM $1900
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul Schenck, Nov 24, 2018.
  1. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    IMG_6424.jpg I removed the mid section and varied it to a welder and pointed to what I wanted and he was able to charge me only $40 to replace it. Then back home and installed it lifting the rear section up 4” because it says as the car ages
    iPhone ?
    Skibob, Shaunius, SFO and 5 others like this.
  2. Shaunius
    Shaunius Junior Member
    91
    24
    City of Angeles
    Paul, when did you change your struts and if so what kind? I'm at 111742 and very worried about the struts :)
    Paul Schenck likes this.
  3. audiodave
    audiodave Active Member
    800
    272
    US
    Kyb's what's popular and I think original.
    Shaunius likes this.
  4. Mendel Leisk
    41,490
    Interesting welding excercise: looks like the original pipe is canting upwards a bit at the Cat. Did the welder manage to stay pretty close to the original angles and length? Employ any tricks?
    Or maybe I'm overthinking it, lol.
    500K miles is pretty stupendous btw.
  5. Paul Schenck
    523
    306
    Fresno, California
    I had the front ones done at 200,000 really made a difference. OEM
    The rear ones I did at 397,000 ordered the spring strut combo replacing them when I had taken the battery out. Easy
    iPhone ?
  6. Paul Schenck
    523
    306
    Fresno, California
    I layed it out on his table and measured up from the end to get it right.
    He tacked it in place so I could make adjustment before he sealed it up.
    iPhone ?
  7. Paul Schenck
    523
    306
    Fresno, California
    I did the front at 270,000 and the rear at 397,00 should have been sooner if I knew I could order strut spring combo units I could change myself would have saved a set of tires.
    iPhone ?
  8. terramir
    terramir Member
    318
    51
    Los Angeles
    since your in California and the ombudsman considered that an improvement can you give us the model number for that cat? Magnaflow right? can you dig up the model number I think more than one person here needs one.
    terramir
  9. Paul Schenck
    523
    306
    Fresno, California
    iPhone ?
  10. audiodave
    800
    272
    US
  11. terramir
    terramir Member
    318
    51
    Los Angeles
    Technically ? he got it approved somehow there must be a way. Although I am still fuzzy on the exact steps. we could use some walk through advice here.
    terramir
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    You're asking too many questions.............hint...hint
    But here...
    Catalytic Converter-2.50in. Universal California OBDII Rear Right Magnaflow CA | eBay
    Exact steps......
    purchase replacement cat
    remove exhaust pipe with cat from car
    take both items to local welding shop
    a good welder/fabricator could swap the cat and maintain exact fitment/angles/etc pretty easily
    pay the man
    take newly repaired exhaust pipe home and install it in the car
    sell the old cat for 200 bucks and come out even on the deal.............
    #12 TMR-JWAP, Apr 2, 2019
  13. audiodave
    800
    272
    US
    Raytheeagle and Paul Schenck like this.
  14. Paul Schenck
    523
    306
    Fresno, California
    I believe you are technically right. Because the emission equipment is technically designed to last the life of the car. Though with 570,000 miles the car has technically died.
    The resuscitation requires slightly more catalyst than was originally provided. This does the job.
    iPhone ?
  15. Paul Schenck
    523
    306
    Fresno, California
    I waited though I believe 170,000 would have been the perfect time.
    iPhone ?
