AT-PZEV question
Discussion in 'Gen 2 Prius Technical Discussion' started by rigormortis, Sep 18, 2007.
  1. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    i looked at the chart in the knowledge base but it wasnt much help but what
    actually happens to the build up of gasoline vapors. does the prius actually
    burn all of it ? while gas is being pumped, the vapors go underground for later pickup
    at the gas station, and when you open the gas cap there is no whoosh
    of some of the vapors due to the anti siphon vacuum thingy
    so what happens to the actual gasoline vapors?
    maybe all of them go underground, dont know
  2. Tideland Prius
    16,408
    The bladder in the fuel tank minimise gas vapours so they don't form in the first place. The "whoosh" is the vapour that has built and is under pressure and when the gas cap is opened, it's released.
  3. richard schumacher
    7,664
    1,042
    United States
    They also get adsorbed onto the graphite particles inside the vapor recovery canister. If the canister gets soaked with liquid fuel it stops working, which is why one should not top-off when fuelling.
