Audio Mute button
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Argyros, Jan 7, 2024.
  1. Argyros
    Argyros Active Member
    274
    141
    2023 Prius
    I recall others in the forum complaining that there wasn't a MUTE button to mute or pause the audio; well, I found the answer to that-
    The answer is on pg. 21 in the Quick Reference Guide-
    Steering wheel switches & telephone controls (Bluetooth® )
    I can't upload the picture (for some reason).
    All you have to do is on the right side of the steering wheel, push the MODE button and hold it to MUTE or PAUSE the audio. I haven't tried it yet, but will be trying it next weekend.
    HacksawMark likes this.
  2. 23PriLE
    23PriLE Member
    95
    67
    North Central Florida
    2023 Prius
    I use the Mode button to mute regularly. One quirk is that you don't push it again to un-mute.
    If you do it acts as a Mode switch and changes the audio source. To un-mute you must use the volume control that's on the other side of the steering wheel. If you forget and hit Mode to un-mute you will have to hit it multiple times to scroll back to your original audio source.
  3. HikeBike
    HikeBike New Member
    Maryland
    2024 Prius
    Limited AWD-e
    Thank you for this tip. I hadn't read through the manual yet, but this will save me the trouble. I confirmed in my '24 this works. Push and hold the Mode button to mute/pause, then push and hold it again to unmute/resume.
  4. Harters
    Harters Active Member
    335
    426
    UK
    Excel
    Same as Gen 4.
  5. Come-Back-Shane
    Come-Back-Shane New Member
    Denver
    2023 Prius
    If you hold down on the Mode button a second time, it will unpause/unmute.
    Zup2sky likes this.
  6. hyperphil
    hyperphil Junior Member
    PA
    2024 Prius
    Limited AWD-e
    If you press and hold (~ 2 secs) the mode button again it will unmute
  7. priusdriver223
    82
    30
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, I mute by pressing down on the knob that adjusts the volume. Whenever you want to unmute, you can just press the knob again. Cheers!
  8. 23PriLE
    23PriLE Member
    95
    67
    2023 Prius
    Thanks for the correction. I guess I just wasn't holding it long enough.
  9. Argyros
    274
    141
    2023 Prius
    Yeah, turning the volume down to zero is not what I was looking for; pressing on the volume button only does that.
    I did try out holding the MODE button for the 'radio', and it worked. The only thing is if you don't hold it down long enough, it will change your mode. Also, pressing and holding it will bring it back as well. Thanks to all that solved that one for me.
    It's such a common thing on cars that I didn't believe Toyota came up with a solution for that.
    Sharol likes this.
  10. Sharol
    Sharol Member
    159
    74
    Kansas, USA
    2023 Prius
    Thanks everyone for this. I checked and it is also (sort of) on page 30 of the multimedia guide. Thought I had checked (the pdf with search), but apparently I missed it.)
  11. garen2001
    garen2001 New Member
    2024 Prius
    Ideally Toyota should have designed the volume nub on the steering wheel such that pressing down on it = mute.
    AndersOne likes this.
  12. dnbinfv
    dnbinfv Junior Member
    32
    Fountain Valley, CA
    2024 Prius
    On my 2024 the steering wheel button mutes the audio.
  13. Lantaral
    Lantaral Member
    65
    30
    US
    2024 Prius
    Pressing the volume knob (next to the screen) does pause audio playback. Pressing it again resumes audio.
    Have tested this with multiple Android Auto apps.
