Auto A/C airflow and cancelling Auto A/C
Discussion in 'Gen 2 Prius Main Forum' started by TonyPSchaefer, Jan 20, 2005.
  1. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Simple post:
    The Auto A/C only blows on the floor. Any attempts to chage the flow to the middle vents turns off the Auto A/C. What gives?
    Additionally, I believe that the ICE runs more when the Auto A/C is on so I shut it down when the car is comfortably warm. However, when I cancel the Auto A/C, the vent is open drawing in outside air. I have found that during the winter in Chicagoland, the outside air is considerably colder than I appreciate.
    So when I cancel the Auto A/C, I have to do this:
    1) Cancel Auto A/C
    2) Switch to Climate view
    3) Change airflow to middle vents
    4) Change vents to recycle
    5) Turn the fan on to appropriate level (1 or 2)
    6) Switch back to the Consumption Screen
    Granted, I've gotten pretty good at it by now. On par with Data manipulating the screens on Star Trek: TNG, but it's still distracting and laborious.
  2. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    You've hit on my least favorite part of the Prius' UI.
    My shorthand way of thinking of "AUTO A/C" is this:
    • AUTO A/C is the Prius trying to be smart about getting the cabin to the desired temperature.
    • However, it isn't very smart.
      • I do notice that under AUTO A/C, the choice of which vent is used (floor, middle, both) changes depending on the temperature setting, the outside air temperature, and the cabin temperature.
        Whenever you turn on AUTO A/C, and then make an adjustment to the Climate screen, the AUTO A/C indicator shuts off -- but A/C is still running. It's just telling you that "you've decided to ignore my advice, so let you heat the cabin on your own, Mr. Smarty-Pants." The settings wills stay that way until you change them yourself.
        Hitting AUTO A/C a second time puts control back into the Prius' temperature computer's control. ("So, you decided to listen to my advice after all. What a surprise!")
        Hitting AUTO A/C a third time turns off heating/cooling completely, leaving you with just air from the outside (unless you recirculate the air). ("Daiiiiissy, Daiiissy, giiiiiiiiiveeeeee....")
        [hr:67a7a83462]
        At this point, I wish I just had the ability to set various temperature configurations (like favorite radio stations), and jump between them.
        But until then, we'll just have to do the Data/Geordi screen shuffle. You can always turn to the person in the passenger seat and say, "Coordinates locked in, sir", giving them the opportunity to say "Engage!"
  3. KTPhil
    KTPhil Active Member
    1,379
    22
    I may be missing something, but I think I accomplish the same thing by hitting AUTO A/C on the steering wheel (once or twice to turn it to full-on auto), then go to the climate screen and turn off the AC (without changing anything else).
    Now when I change temp, obviously it can't go lower than outside temp (not your problem I take it!) but it WILL adjust the heat and blower to accomodate your desired temp. You can also select or deselect recirc.
    The setting doesn't always surive a reboot, er, restart-- I'm not sure!
  4. 8AA
    8AA Active Member
    550
    62
    Maryland
    And if you can talk your dealer into it, he can set up the car so that pressing AUTO doesn't automatically turn on the compressor. When you want air conditioning, you go to the CLIMATE screen and press the A/C button.
  5. sfmark
    sfmark New Member
    San Francisco, CA
    Is this documented anywhere so that I can show my dealer? It sounds like a really good idea to prevent overuse of the air conditioning. Here in San Francisco we don't have much use for it, even in the summer.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Tony,
    Skip the steering wheel button step.
    Lemme see if I can do this from memory:
    (assuming you're in Auto AC at 67 degrees)
    1)Climate Button
    2)AC button on MFD (Auto button should stay lit)
    3)Adjust temp with arrows if necessary
    4)Hit the fan speed you desire (Auto button should go out)
    5)Hit fan pattern you desire
    Yea, it's still a pain in the butt when a single simple button that says "VENT" would prevent most of the button pushing.
    BTW, it won't "Always" blow on just the feet, it depends upon a number of factors (chosen by Prius Climatology Gods), but depending upon your desired temp, starting temp, outside temp, humidity, how close you are to starting your menstrual cycle, and planetary alignment patterns may choose other settings. I usually get both feet and a cold blow in the face at full fan power at start-up if I'm in AutoAC in cold weather!
  7. efusco
    19,891
    1,196
    Nixa, MO
    Here You Go
  8. Robert Taylor
    Robert Taylor New Member
    451
    Rocket City
    Most interesting.
    So, the A/C button on the far upper left of the MFD while in Climate settings cuts the compressor on and off or just enables it?
    I am still working my way through all the manuals.
    Thanks in advance for the response.
  9. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    This has happened to me a few times, most recently this morning, even though it does not get quite as cold here as it does in MO. However, within a minute it automatically shuts off until there is sufficient engine heat for the climate control system to work properly.
  10. IsrAmeriPrius
    4,333
    Southern California
    It toggles the compressor on and off.
  11. KTPhil
    1,379
    22
    "Foot Air Leak" is another dealer-settable option. This may be the source of your cold air to the feet, since it is ON by default ("on by da foot?").
    I am not 100% sure, but the AC button (when yellow/on) in the climate screen doesn't force the compressor on, it just allows it to cycle as required if the outside air is warmer than your set point. Turned off, it won't run at all.
    Come summer is SoCal, it won't matter, becuase it will be on all the time anyway! But now in winter, the cooler air means less AC and less penalty for low temps.
  12. Tideland Prius
    16,556
    Yes, the beauty of automatic climate control is that you don't get blasted with cold air. It will stay off until sufficient heat is available, although I realise that sometimes it still blows cold air.
  13. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I also think it odd that auto A/C chooses foot-well (almost exclusively). In the winter it is pretty useless. Front window (all cars) will fog up if there isn't at least some air flow. I think it should auto choose defrost/foot-well any time the 'snowflake' icon is lit. And, it should honor a different vent setting while still doing auto temp control by adjusting the fan speed and A/C.
    As such, I've not been using Auto A/C lately. I set the vents to defrost/foot-well, temp to MAX HOT so the electric heaters will go on and I switch to defrost when necessary. I can do that with the steering wheel button, but to go back to defrost/foot-well I have to use the climate screen. My commute is pretty short so I can adjust the fan speed to control cabin temp. Just like all the other cars I've owned. Too bad since Auto climate control is a nice feature.
  14. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I noticed yesterday that when I lowered the temperature to the point where the heat cut out, the air started blowing in via the dash ports. When I raised it back up to the point of the air being warmed again, it went back to not blowing directly on me.
    Maybe some Toyota engineer gets a nosebleed from warm air in his/her face, and decided to save the world?...
  15. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Bruceha_2000 said "think it should auto choose defrost/foot-well any time the 'snowflake' icon is lit."
    exactly! very well thought out on that one.
  16. rick57
    rick57 Member
    572
    Circleville, Ohio
    I'm going to check on the "body customizing settings" in the morning. I forgot about that on the Prius. I know that the Highlander,Sequia,4-Runner,etc, you can change different items. But around here not to many people know about it or ask to have any changes done. :roll:
