Auto crossing a Prime
Discussion in 'Prime Main Forum (2017-2022)' started by glenthompson, Jan 20, 2018.
  1. glenthompson
    glenthompson Junior Member
    Williamsburg VA
    2022 Prius Prime
    Anybody autocrossed their Prime? Since I’m in between competition cars for a couple of years I want to keep my skills up and the Prime is the only car I have that’s suitable.
    I’m wondering about the best settings for max performance. On my older conventional Prius I ran it in B mode so the engine stayed running. Also turned off traction control and stabilization. On the Prime Advanced I obviously have to turn off all the safety systems. Wondering about engine settings. Was planning to run in hybrid mode, in B gear, and performance mode.
    Any other suggestions?
    HPrimeAdvanced likes this.
  2. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    I'd run the car in CHG while in line for the run, then HV for the actual run.
    B might keep the engine revs up, but will reduce regenerative braking. In a Prime I think you're best off doing that, in a Liftback you might not be.
    PWR isn't necessary - wide open throttle is wide open throttle regardless of mode. Pick the mode that gives you the best modulation of throttle for how you like to drive.
  3. Tideland Prius
    16,401
    Yeah I'd keep it in HV mode. I can't remember if it's in the owner's manual but I did read somewhere that the Prime doesn't really like to be constantly charged and discharged (e.g. auto-crossing) vs. the regular Prius (who's battery is designed to have constant charge and discharge under normal hybrid operation).
    HV mode will limit the amount of fast discharge (due to acceleration)
  4. priusalex
    priusalex Junior Member
    Atlantis, FL
    There’s a little sporty motivation for ya
    2010 Prius IV
    #4 priusalex, Jan 20, 2018
    priuscatprimeguy likes this.
  5. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    Don't know about autocross, but someone did this mod on the Plug-in Prius:
  6. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Nice field.
    No gopher holes, stumps, ditches, stump holes,rocks, limbs - the stuff that could really wreck up a prius.
    sonomac likes this.
  7. padroo
    padroo Senior Member
    2,763
    2,251
    Autocross in a Prius, I know a guy on another form who does it in a Lincoln Town Car.
    It looks like a lot of fun.
    What will be your competition?
  8. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I autocross with the Central PA SCCA once a year so I'd be interested in seeing how your Prius standings compare to the other car.
    There is a button on the right toward the top of this page for a list of the competitors, their cars, and their times from 2017's Solo Event 1:
    2017 21st Century Automotive Challenge
    I'm not good and don't claim to be but I did beat a Miata.
  9. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    I run my Prime Advanced in EV and POWER mode and have "played" with getting around slower cars in moderate traffic, also dodging freeway onramp HOV lane cheaters. It ain't slaloming, but that puppy do run. Another really fun place is climbing out of Brea here in Socal, with all the twists and turns, the car is really fun! I think you could have a lot of fun slaloming against Corollas, Civics, Accords, basic Ford Fiestas & Focus, Fusions. The tires are CRITICAL. Strip everything easily removed from the car; lower gasoline level to minimum. Locate nearby L2 charger. HAVE FUN!!
    benagi likes this.
  10. glenthompson
    Williamsburg VA
    2022 Prius Prime
    My Prime did reasonably well. I finished 33 out of 43 in overall PAX (a handicapping system to compare different performing cars). I was the only car in H-Street so no direct competitor. Only significant issue was severe understeer. If I had more time to play with tire pressures I might mitigate that some. Better tires than the stock Toyos would help a lot.
    My best runs were in EV mode. Course was about 0.6 miles long and display showed about 2.5 miles of range used per run. Except for the understeer, the car handled very well. Consistent through the slaloms. I did have all the safety features turned off as well as traction control.
  11. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Very cool!! The EV mode feels very quick to me, and coupled with the POWER mode setting the car feels quite responsive for that relatively slow speed of slaloming. Definitely play with the tires; I assume you have a "can" of compressed air to adjust tire pressures; that's usually quicker than using a 12 volt compressor.
    You should contact the AROSC (Alfa Romeo Owners of Southern California) who have offered "other" car categories. They hold a number of different competition events from slaloming to solo 1, and rallying. I haven't been in touch with them for many years, so I hope they're still active. Good luck!!
  12. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    I just noticed that you're in Virginia? Alfa Romeo Owners National Club was one of the biggest and oldest sportscar clubs in the U.S. You'll probably find a local, welcoming chapter that holds events in your area.
  13. vvillovv
    vvillovv Senior Member
    4,315
    1,494
    NY
    was gonna ask if you are/were planning to to use EV at all and if you were/are what ya plannin to do with B when the ICE kicks on?
    Alas: I see that issue was address in the first two replies....
    OdaTORment
  14. Prodigyplace
    12,364
    11,660
    Central Virginia
    vvillovv likes this.
  15. glenthompson
    Williamsburg VA
    2022 Prius Prime
    I’m a 20+ year SCCA member. No problem finding events. Most events I attend in the SE Division I run into someone I know.
  16. a_gray_prius
    2,927
    783
    IL
    My butt dyno -based answer would be to run in EV mode, assuming you have a pretty tight course. I feel like the pedal mapping and power curve is pretty different between EV and HV modes (where HV modes have the car spending more time revving up the engine - soaking up precious time when you're transitioning out of corners).
    If you get lots of runs in like our local Miata club likes to do, you might as well try both a few times and see how you average out.
    Also: there's understeer, but I can't help but feel like moving to stickier tires would come at some cost due to much greater rolling resistance (I ran AD08s on my other Prius for a while).
  17. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    But for most owners the Prime runs in HV mode quite a lot. I know the traction battery is divided into EV and HV sections, I had thought that's probably just a virtual separation done in the software, but maybe there are actually two separate groups of cells within the battery case, one group set aside for EV and a smaller group of cells used for HV, with each group of cells optimized for that particularly use.
  18. Tideland Prius
    16,401
    Well I was thinking battery chemistry. Both Prius and Prime have Li-Ion battery but I think it was a Toyota engineer that said those two chemistries are different because they're used in different applications - the Prime is designed to be fully charged up and then discharged (to the HV level) and the Prius is designed to be constantly charged and discharged with its smaller capacity. Thus the Prime isn't as happy with the same frequency of charging/discharging as the Prius would be.
    I thought it was a virtual partition too. It could be a physical one as well. Have you seen Weber Auto's disassembly of the Prime's battery? It is made up of several cell modules so it's possible two out of the 5 modules could be the HV portion, for example.
    Since2002 likes this.
  19. Prodigyplace
    12,364
    11,660
    Central Virginia
    If that is the case they need to make it clear that the Prime is not a Hybrid but an EV with a large range extender. The large extender disqualifies it from officially being classed as an EV by CARB.
  20. Tideland Prius
    16,401
    Is that what the Volt falls under as defined by CARB? (Didn't realize that category existed).
    Also, the Prime is classified as an EV? since when?
