Auto Window
Discussion in 'Gen 2 Prius Technical Discussion' started by buzzard bill, Nov 23, 2007.
  1. buzzard bill
    buzzard bill New Member
    23
    Escanaba, MI
    How do you reset the AUTO window on the drives side after you have disconnected the battery.
    Thanks
    Bill
  2. Tideland Prius
    16,402
    If the auxiliary battery is disconnected or run down, the power window may not operate automatically and the jam protection function will not function correctly after you reconnect, replace or recharge the auxiliary battery. In any of these cases, you should normalize the power window.
    To normalize the power window:
    1. Push down the power window switch and lower the window halfway.
    2. Pull up the switch until the window closes and hold the switch for a second. Make sure that the window opens and closes automatically. If the power window cannot be operated properly, have it checked by your Toyota dealer.
    Page 41 of the owner's manual ;)
  3. buzzard bill
    23
    Escanaba, MI
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 23 2007, 02:33 PM) [snapback]543303[/snapback]</div>
    Thanks. Window works fine.
    Bill
