1. lordgreystoke422
    lordgreystoke422 New Member
    Nawlins Luziana baby!
    I am the original owner of a 2005 Prius. I currently have 91.5K miles on my car. I THINK my Traction Battery is heading for the big junk yard in the sky.
    I understand the warranty is 100k miles on my battery but I wonder if there may be conditions which may void my warranty. I apologize for any excess info but am trying to be thorough.
    Two months after purchase I suffered a severe accident which damaged my front passenger side/fender including snapping the right tie rod. It was repaired at the Toyota certified place locally. Then I had a pallet fly off a truck and damage my front bumper while coming back to New Orleans after Katrina on Oct.2. This was a minor incident..then I had a hit and run which crumpled my front fender but seemed to be body damage only. 2 weeks later a flatbed tow truck I guess, backed on top my hood and scraped my paint through to the metal..more cosmetic damage, another hit and run. I was pretty disgusted at this point and just left it that way till post Katrina insanity calmed down.
    I have run out of gas a few times. One time the Battery was drained to where I had to push it the last block to the gas station after the first gas station I was shooting for was closed.
    Having suffered Katrina..and had to live in ways I hope none of you ever do..I spent more than quite a few nights..sleeping in my Prius with the car running and the air conditioner running. I suspect my Prius has a significant amount of extra duty on its engine and battery that a person under normal conditions never would experience.
    Ok...now to the problem. This morning I noticed that my Prius seemed to have some power drop outs. I switched over to my MFD(Battery Gauge) it showed my traction battery with one bar. I began observing it and noticed that it was not charging back up despite the arrow showing power going to it. I turned my AC off to allow it faster recharge and still no postive charging to more bars. I stopped and let my car run when I jumped out for about 2 minutes and came back to find my indicator showing green and I think seven bars. I turned on the AC and took off and the bars dropped away in under 30 seconds. With my extreme deductive reasoning I have come to the conclusion that there is something wrong. (and they say we are all dumb in Louisiana). I have suspicions that this is another thing that Katrina is indirectly coming back to kick me with. I took some video of my MFD(apologies if I am getting this wrong) and I will post it on Youtube with a link later if any of the gurus take interest and think it useful.
    I have not yet had the opportunity to take it to the dealer since this problem started.
    What I would like to know are:
    1)What may be the problem.
    2)If it IS the battery will they cover me based on what I have said.
    3)If I don't volunteer all the above info will they know how many hours my battery has?
    4)If it is the battery and they will not cover it, (I had a friend with a shop price a battery and it was $2900.) are there better/cheaper options for replacement(that dont take my whole spare tire out or cost 9 grand). I do have the skill level to install the battery myself if I go Non-dealer but overall...the 2.1 hours labor saved isn't so much worth my time when balanced with the extra danger of handling a High Voltage battery. Also, I'd like to pass on a more efficient Prius to who ever I sell it to when I buy my 3rd generation so I am willing to bite a little extra bullet for the common good...plus being a capitalist pig...I will charge them over book for that.
    Thanks for suffering my novella...please forgive my poor attempts at humor and lack of brevity..any help is much appreciated.
  2. Patrick Wong
    18,200
    6,490
    I'm very sorry to hear about the difficulties that you've had with your car and having to deal with the aftermath of the New Orleans flooding.
    Regarding the accident damage that your car suffered, this does not appear relevant to your current traction battery problems. If your car has not been flooded, then I see no reason why your hybrid system warranty should not be honored.
    Based upon your description of the SOC gauge rapidly moving up and down, I would say that your traction battery is on the edge of failing; however nothing will be done until your instrument panel lights up like a Christmas tree.
    In the event that no warning lights come on until after the traction battery warranty has expired, then you can buy a salvage battery for ~$500 and have your mechanic friend download Toyota repair manual info and install for you.
    techinfo.toyota.com
    Good luck.
  3. lordgreystoke422
    Patrick,
    Can you describe the LIGHT UP like a christmas tree a little better. Do you mean all the lights on the panel coming on?
    OT: I experienced this before at times when I had a broken ground wire on the rear of the car that I finally found. The instrument lights would all light at times when I put the car in reverse and stay that way until shut off. Other functions affected by this broken ground wire more prevantly were the lights blinking hazard fashion when the turn signal was used and the cruise control acting funny when the turn signal was used with cruise engaged.(The cruise would stop keeping the speed steady and the cruse light would flash and not work until the car was shut off and on again. I havent actually soldered this in place yet so maybe I will take pictures of my repairing this along with the problems it caused and post it here as a DIY repair if it doesnt already exist.
    Back on topic:
    I have noticed that since it has gotten dark my battery seems to be moving through a cycle and moving above one bar and accepting some charge even with the AC running...it seemed to improve as the outside temperature went down. This makes some sense to me with a failing battery as temperature can play a role in battery failure.
    Also...So basically I am going to HAVE to continue driving with this diminished battery until ABSOLUTE failure to qualify for my warranty? This doesnt seem so great for the engine and overall car. I was feeling kind of dumb for continuing to use my car today but if I am understanding correctly..its what I HAVE to do to get it to die completely and get the warranty? Obviously a trip to the dealer needs to happen in case its something else..but I suspect the brain trust here tends to know more than most techs do at the dealer..they just lack the actual car in hand to make the proper diagnostic judgement.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    A sufficiently capable scantool can look at the battery block
    voltages, and record some of the data while various driving tests
    are done on the car. That would at least help tell you if one
    or two modules are failing, or the whole pack is toast. The
    highest likelihood is one cell is weak which as silly as it sounds
    can ruin your whole day, but it may be quite possible to replace
    one or two bad modules with approximately equally-aged others
    [i.e. new ones would create more of a mismatch] from a salvage
    pack and keep goin' on down the road.
    Failing a scantool, if you're willing to romp around in the
    high voltage world and know how to be safe about it, you might
    be able to find ailing modules with just a voltmeter.
    _H*
  5. Patrick Wong
    18,200
    6,490
    I am wondering what was the cause of the ground wire problem in the back of the car. Was this due to an accident? By all means, if you are aware of any current wiring harness problems you should ensure they are correctly repaired.
    Once the traction battery fails, I would expect the master warning light (red triangle) in the combination meter, and the hybrid vehicle icon (the outline of a car with an ! point within) or the battery icon to appear in the MFD.
    As Hobbit indicated, the Toyota tech would be able to identify the battery module pair voltages, etc. if you are willing to pay for an hour of diagnostic time. However it is unlikely that anything will be done to fix the situation, until the battery fails sufficiently so that the warning lights described above turn on.
    If you have mountains in your vicinity, you may wish to speed up the mountain roads at the fastest (yet safe) speed feasible, to see how the car and the traction battery SOC behave under heavy load. Such a load may also provoke the battery to fail, which is what you want to happen before you hit 100K miles.
    A diminished battery is not going to harm the engine or the rest of the drivetrain, however you may notice an mpg degradation as the engine runs a greater proportion of the time than normal.
  6. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    I've got no personal experience in this matter, and anything I say is second-hand anecdotal, so take it as you see fit. That being said, from the things I see written about here on Prius chat, I suspect that this will be your biggest obstacle to getting the battery covered under warranty.
    I highly doubt that Toyota will know or care about the "extra hours" on the battery from idling while sleeping, and from what you described it doesn't sound like any of the collision damage will affect the battery warranty.
    On the other hand there seem to be frequent warnings throughout this discussion forum that running out of gas might mean losing your warranty coverage. Running out of gas and continuing to drive until the car dies from a drained HV battery, seems to be frowned upon even more. Running out of gas multiple times, and continuing to drive the vehicle. . . .
    Let us know what the dealer says if you go that route. You'll either be able to silence a bunch of doomsayers around here, or you'll be a prime example of why we should take care not to run out of gas.
  7. Patrick Wong
    18,200
    6,490
    Good catch Danny; I had missed those two sentences from the OP's original msg. This may well explain why the OP is having battery difficulties now.
  8. lordgreystoke422
    Yeah I had seen mention of that in a few threads about the running out of gas. Ya know...the thing about it is...if running out of gas voids the warranty..or is bad for the battery..they should make a little greater effort to inform consumers about that. That non withstanding I appreciate..ya run out of gas...thats your own bone headed fault. The part that bothers me about that is..Our cars are SO ADVANCED in their power management, if Toyota knows this is a severe problem for the battery the car should shut down when you run out of gas....JUST like a regular car. I'll be honest..the first time I did it..I was headed to the station after doing a tank..I think I might not be the first person that maybe pushed it a shade too far for giggles to see what he could get out of it. The time I REALLY had a problem was post katrina and I had trouble finding a station open where I was later in the evening..in "highly populated area".
    The more I think about it..the more this bothers me...running out of gas happens sometimes even to very responsible people. Thats why AAA has gas delivery as part of their road side assistance.. I think that this should be addressed better to people and a "WARNING: Driving while out of gas may damage your Traction Battery. Proceed only under extreme emergency!" should flash on the MFD and you have to hit an agree button to continue..
    I will let you know what happens to me.
  9. richard schumacher
    7,664
    1,042
    United States
    After mulling this for four years I've come to agree: whenever it thinks it has run out of gas the Prius should simply shut down, and not move using only the traction battery. The ability to drive one more mile is not worth the possibility of expensive damage that can be done to the traction battery.
    Time spent idling (the car "Ready" and in "P") is exactly equivalent to time spent moving, from the point of view of the engine and the battery. That time did no harm whatsoever. Repeatedly running down the traction battery after running out of fuel is what hosed you.
  10. lordgreystoke422
    Richard,
    I tend to be big on personal responsibility and when I first posted was really accepting my own actions in potentially voiding my warranty and expecting to have to buy a battery. As we have discussed this I have thought more and more about my gas failures. I do know I was unaware that I was potentially killing my battery and with that knowledge I doubt I would have pushed my luck. I recall the first time it happened...I was used to getting a known amount out of my tank..and for whatever reason..this tank I got 40 less and had a OH HECK moment...and thought..WOW..how cool..its a little safety net for goof ups.
    As I said before...we all have marveled at the complex series/parallel dance of our Prii which makes the Toyota system so superior to other hybrids. So it just seems like a failure on Toyota's part towards its customers during a time a customer may not be thinking as logically as they should. Also, with all the different sorts of batteries we deal with today..its easy to confuse what is bad for a battery. Expensive lesson...but what ya gonna do..
    Honestly with some of things I have been through...I MAY have still done things the way I did them anyway. I just would have made the decision knowingly. I know that I assumed my Motel Prius nights were going to kill my battery at an earlier mileage than most and did that knowingly. I planned on selling the car a bit under the going rate when I sold it so as not to screw the next guy(I was hoping 3rd gens would be out by now). I also know that the time I shagged the battery the worst(assuming the run out of gas incident is the cause)...I had the time to walk and get the gas...and very well might have parked it and made some calls. Ahh who knows...maybe I can play the Katrina card on them and they will show me mercy...heck if they give me a new battery at cost or a nice discount I think I might do that even over a salvage battery for less.::dreaming::
    One other thing I have noticed since I started writing this mail hours ago..
    There seems to be a definite heat issue with the battery...the hotter it is during the day the less able the battery is able to charge...even with the AC on max at night which should be causing similar strain.. I wonder if there is a fan on the traction battery that may be going bad...or maybe my cooling system needs a flush? Hopefully I can get in Monday and get checked out.
  11. EngMarc
    EngMarc Member
    61
    42
    Pittsburgh, PA
    Ok, I’ve written about this a few times on here but saw the “Running out of Gas” and “Prius should just shut down” remark a bit draconian.
    Prior to my 2013 Prius, I drove a 2008 SMART ForTwo Cabriolet (quite loaded with all the bells an whistles even more so than my Prius Model 5). However, the SMART car even in the base stripped down models has a fuel gauge that shows large quarter tank increments similar to the Prius gauge. HOWEVER, once the warning light on the SMART ForTwo comes on showing low fuel, the fuel gauge starts counting down from “1.0” gallon by tenths until it hits “0.0”. This as compared to the Prius which when getting low on fuel (not sure how low and even Toyota states in their manual they aren’t sure how low), the fuel indicator will start flashing with an audible single beep. That’s it!!!! Toyota states in their manual that “once this sounds” you have approximately 97 - 49 miles to empty. Now the MFD (display computer) has a trip meter to show Distance to Empty (DTE) which is useless as most of the time once one gets to a ¼ tank, the DTE displays “0”. I drive a lot of miles (oike 30,000/yr) so quite often find myself cruising along on the highway listening to music or a podcast and happen to look down at the display and there’s a flashing fuel gauge - never knowing exactly when it started flashing and feeling that ‘Oh Shit’ moment in my stomach. Iff you look online you’ll find out that most every other automobile manufacturer has detail readouts (for digital OBDII monitors) from the fuel sensor EXCEPT for Toyota!
    So in summary, Toyota doesn’t equip their fuel tank with a sensor that is accurate below about 1-2 gallons. This is born out by the number of times Prius’ are towed into the dealer for running out of gas (don’t believe me ask your dealer - it happens more often than you would think!).
    The engineering fix for this would simply be a better more accurate fuel sensor so the driver knows EXACTLY what is in the fuel tank.
  12. bisco
    50,815
    rant over?:p i think they've improved the gen4. while i would like more warnings on gen 3, filling up at the beep, or driving another 50 miles isn't a huge deal. and there are 2 gallons left, it's not iffy. anyone being towed to the dealer for running out of gas just wasn't paying attention, or forgot to fill up after the beep, then forgot altogether. i have been guilty of that.
    btw, i ran out of gas in my '04, drove until the battery died, put 3 gallons in, and was on my way. my neighbor owns the cr today with 14x miles, and the original battery, still getting 50 mpg.
    Raytheeagle likes this.
  13. dolj
    dolj Senior Member
    8,113
    4,127
    Wellington, New Zealand
    @EngMarc, since the Lord Grey Stoke has not graced this site with his presence in over 4 1/2 years, I doubt there is much value to him in you reviving this 8+ yo thread.
    #13 dolj, Nov 29, 2016
    fotomoto likes this.
