Battery charging on long downhill
Discussion in 'Gen 3 Prius Technical Discussion' started by larrymcg, Nov 8, 2010.
  1. larrymcg
    larrymcg Junior Member
    Redding, CA
    Curiosity question. I've noticed that on a downhill of a couple miles, especially in "braking" mode or with the cruise control on, the motor/generator and engine are used to help keep the speed down and the battery gets charged to the very top quite quickly. That's good!
    On a really long downhill, will the motor/generator still be used for braking and the excess electricity discarded to keep from overcharging the battery?
    --Larry
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Yes. The system switches to engine braking, which discards the excess electrical energy by spinning the engine. Obviously there are limits. If the required braking exceeds the electrical capacity, friction brakes are brought into play.
    Tom
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    And on really steep and long downhill sections your friction brakes work like every other car. This means they heat up and become useless. So next time you decend Pikes Peak, just remember that the regen braking is cool for the first few hundred feet, then the friction kicks in and they get hot. I see lots of cars coming down from Pikes Peak where their wheels are glowing red or smoking because they didnt stop at the required brake checkpoint and cooling stations...
  4. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    It is better to use "B" to help friction brakes make their job.
  5. larrymcg
    Redding, CA
    By "braking" mode I meant "B".
    I don't see how spinning the engine uses electricity. My understanding is that the system puts the engine into the drive line, but without giving it any fuel, to use the engine's compression to slow the car down. How does that use electricity?
    Also, is it really true that in "B" the system will apply the friction brakes as needed? I'd be real surprised if it did that. For one thing, no specific speed has been set so the car does not know if you are going too fast. I'd also be surprised if the system applied the friction brakes even if the cruise control is set. I certainly have not seen that happen and I've let the car go way over the cruise control set speed while coasting down hill. If it applied the friction brakes I would expect it to keep the speed down.
    Hmmmmmm.......
    --Larry
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Under some circumstances the car will use MG1 to spin the engine, just as it does to start it but with no fuel applied, to use excess energy.
    As far as I know the car will not automatically apply friction brakes in the B mode. Cruise control is canceled when you select B.
    Also of interest, the B mode does regenerate but not at the maximum rate. You can increase regeneration, in B or D, by using the brake pedal and putting the HSI indicator bar farther to the left, if you put it clear off to the left you start using friction brakes in addition to regeneration.
  7. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Nice to hear someone understands how the regen works.
    2 people like this.
  8. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    I tested cruise control in long tunnel, 5.5 km downhill, in Norway, "D" mode selected. The car was not able to maintain preseted speed - 75 kmh - just with regen braking, no friction brakes applied if I can say.
    I had to use friction brakes by pedal to get the tunnel speed limit.
  9. qbee42
    18,058
    3,076
    Northern Michigan
    The engine in the Prius is always "into the drive line", as are MG1 and MG2. There are no clutches or shiftable gears which would allow otherwise.
    Regenerative braking uses MG2 as a generator. Normally the electricity from MG2 is used to charge the HV battery. Engine braking occurs when the SOC of the HV battery is too high, or B mode is selected. During engine braking, MG2 acts as a generator, but instead of charging the HV battery, the electricity from MG2 is used to spin MG1 which in turn spins the engine as a big air pump, thereby dissipating excess energy. Note that this is not an all or nothing proposition - engine braking and battery charging can occur at the same time.
    You miss-understand the phrase "apply the friction brakes as needed." The braking system in the Prius responds to pressure on the brake pedal. Increasing brake pedal pressure tells the Prius to regenerate more power, thereby provide more drag. Eventually regeneration hits a limit and can provide no additional drag. If more is requested by increased brake pedal pressure, the Prius has no choice but to activate the friction brakes. This is what is meant by "apply the friction brakes as needed."
    Tom
