battery charging
Discussion in 'Newbie Forum' started by doggiela, Jun 3, 2011.
  1. doggiela
    doggiela New Member
    CA
    Hi Everyone,
    question: if i go down hill for a long time. say 4000 feet long vegas drive, and i use regular "drive" mode - D, when the battery get full due to frequent brakes, will my car explode?
    sorry for the dump question.
    because i plan to go to Vegas very soon with this prius.
    Please let me know.
    thanks,
    :eek:
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    No you're car will NOT explode.
    You will benefit from switching to "B" once your battery is fully charged though. That lets the engine do some of the slowing that was previously happening by charging the batteries.
  3. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    When you go downhill and need to slow, Regen fills your battery.
    Once you battery is 'full' the engine begins to act as a an air pump, to waste energy so the brakes do not overheat. (This has the odd effect of pressing the accelerator making the car quieter, and letting off it makes it louder, counterintuitive) If you want, you can shift to B when starting the downhill, that will use all 3 systems.
    And of course, your disc brakes still work, they just get hotter and hotter. If you worry, take a rest break for your brakes.
    (what direction is Vegas a 4000 foot drop?)
  4. doggiela
    doggiela New Member
    CA
    thank you very much for a detailed explanation.
  5. doggiela
    doggiela New Member
    CA
    sorry, i forgot to answer your question. Go North from California to Vegas you will climb up to 4000 feets. Then downhill to Nevada State.
    :welcome:
  6. richard schumacher
    7,664
    1,042
    United States
    The rule is: if you need the brakes constantly, shift to "B". This helps keep the brakes from overheating. When you no longer need "B", if you forget to shift back to "D" fuel economy will go down but no other harm will be done.
  7. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    We may have different Ideas about how big California is. [​IMG] It took me 17 weeks to walk up California.
    I am going to guess you are coming over Cajon Pass on I-15 which does attain 4,00 foot elevation, but does not drop 4000 feet , Victorville is still 2,700 feet and Las Vegas is 2,000 feet.
