Battery ecu
Discussion in 'Gen 2 Prius Main Forum' started by Paul S1971, Jan 13, 2024.
  1. Paul S1971
    Paul S1971 New Member
    London
    i-Tech
    Had my 2008 Prius hybrid battery serviced and found issue with battery ecu,very badly corrosion on pins,one is really bad,is it worth buying a new ECU or can it be fixed?seem plenty 2nd had ones on eBay but feel I could be buying one like I've got,any help with this??
  2. Tombukt2
    Tombukt2 Senior Member
    11,643
    2,059
    Durham NC
    Usually high quality contact cleaner cleans that mess right up and if you open the case and look on the other side of the receptacle set the green board down on a light table which can just be an opaque piece of plastic with a fluorescent light underneath it and then you can look at all the traces on the green board running to the silver steel lugs that turn into the pins and the receptacle on the ECU unit I rarely see these eating through or anything like that and usually just cleaning them heals everything working is yours the red label or the black label ECU You just look at the label and do you see black or red and silver of course? The black is the latest one
  3. PriusCamper
    PriusCamper Senior Member
    11,873
    4,817
    Pacific Northwest, USA
    Yep... Toyota Stealership is making a fortune selling brand new battery packs for the error codes that wee bit of corrosion makes. They also charge $800 for replacement ECU. Lol... So Dishonest.
    The main concern with this is where those pins connect to the circuit board. So open it up and make sure there's no corrosion on that first pin thick enough to create micro-shorts with the pin next to it, which creates that familiar Prius symptom of your car's display screen suddenly going from 5-7 bars down to 1 bar. And because the source of this corrosion is coming from completely normal micro-seepage from the seals at the battery terminals, you're going to want to replace those wires, aka: "Wire, Frame, No.2" and clean the bus bars, etc.
  4. Paul S1971
    London
    i-Tech
    Mechanic has opened it all up and cleaned it all,I saw myself one of the contact points was very badly corroded, virtually rooted away,I've taken care to a Prius specialist and he said it's had water damage inside the boot and car is 15 years old,I've had bands etc all renewed on hybrid battery and all serviced,can it still be driven with a red triangle and would it go in limp mode??
  5. Tombukt2
    11,643
    2,059
    Durham NC
    It can still be driven generally with the red triangle on but what's the code limp mode probably not depending on codes present.
  6. Paul S1971
    London
    i-Tech
    I am going to collect car tomorrow and ask for the codes,I've contacted an ECU specialist and he said he can open it up and check inside for corrosion and hopefully sort it out but fingers crossed,I sent him your first reply and he confident he can sort it,many thanks for your help
  7. Tombukt2
    11,643
    2,059
    Durham NC
    Yes it shouldn't be a big deal at all Make note of the color of the label on your battery ECU generally you want the black label The red one is the older but if it's working I guess it doesn't matter but if you wind up at a break or yard I always try to grab the black ones when I see them I'm sure he'll sort it out and short order.
  8. Paul S1971
    London
    i-Tech
    Hi just checked ECU mine is red label
  9. Paul S1971
    London
    i-Tech
  10. Tombukt2
    11,643
    2,059
    Durham NC
    So when it's all cleaned up and back in service and the bus bars and nuts are clean so on and so forth everything should run pretty much spot on unless you have some low or out of range modules in your battery pack but the ECU should be fine black or red I have a few reds in service here. I think the black is just the latest ECU in that series or maybe the last one made I don't know whichever.
  11. Paul S1971
    London
    i-Tech
    Got to garage asked mechanic to take off ecu so I could get specialist to cleaned it etc but he refused,said had to take car away,asked for codes but didn't give me any just said it was ECU,booked into another Prius specialist that fixes ECU and said he will put diagnostic on it,strange thing was 20/12/23 triangle came on,changed 12v battery and was fine up to now ,hope this person can sort my car out
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    This is a very common and very easy fix. Sometimes you can be lucky and the corrosion will be very light. Other times, it's so bad pins will actually rip out when you try to unplug it. Either buy a new ecu from Toyota for 800+ or get one from ebay for <100. Just make sure the seller provides good photos of the pins so you can verify they're clean. Heck, I have a dozen of them on the shelf. The black label ones are the earlier versions, the red label is the newer. Should be a 47092? if I remember correctly. Any of them will work, as I've had various ecus in various HV batteries in various cars. And yes, it would be best to get a new wire harness from Toyota, since there will be corrosion in the harness plug also. No sense doing a job only halfway. They're only 60 bucks new. I have a handful of those also.
  13. Paul S1971
    London
    i-Tech
    Got to bottom of issue,had diagnostic and was break in system,garage that serviced hybrid battery broke wire in band and most nuts were rounded and cross threaded so was all taken off and replaced,ECU had to be changed too as it was scorched,cost me £250 but all working now,going back to original garage who replaced all this in service tomorrow but iam sure they will deny an wrong doing,
