Battery in the trunk
Discussion in 'Generation 1 Prius Discussion' started by bigblock67, Jul 20, 2011.
  1. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    Is there an alternatiive source to purchase the small batttery in an 02?
    50,803
  3. bigblock67
    171
    35
    Indiana
    2002 Prius
    50,803
    welcome.
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  6. bigblock67
    171
    35
    Indiana
    2002 Prius
    Good link. Good info
    Thanks
    Don
  7. ChapmanF
    16,943
    Some were compared in this thread. Don't ignore the upgraded model from Toyota (part no. 28800-21190) which showed in the comparison as a reasonable, competitive choice on both price and specs.
    -Chap
  8. bigblock67
    171
    35
    Indiana
    2002 Prius
    Went and ordered one on line from an Ohio dealer. Good price.. Hope its ok. Thanks for the tip
    Don
  9. Patrick Wong
    18,200
    6,490
    If you have ordered the Panasonic battery from a Toyota dealer parts dept (which Chap referred to in his post above), I hope that you also ordered the conversion kit which provides a new battery mounting bracket and terminal connectors.
    Otherwise, you will have to fabricate or procure those parts yourself.
  10. bigblock67
    171
    35
    Indiana
    2002 Prius
    I didnt order the kit. Will try to handle it. Thanks for the warning.
    Don
  11. ChapmanF
    16,943
    If the battery you're taking out says Panasonic, the upgrade was already done and you don't need the kit.
    If the old one says GS, the kit would be a great investment. It's cheap, safe, and gives you a perfect fit. Between scrounged parts and your time to kludge something up, evaluate it for safety, etc., I'm not sure how you'll beat $31.
    The kit p/n was in the linked post, but it's 04003-23147 in case you missed it.
    -Chap
  12. bigblock67
    171
    35
    Indiana
    2002 Prius
    Dealer in Ohio decided they dont ship batteries.?
  13. Patrick Wong
    18,200
    6,490
    Yes, that is true for most Toyota dealers who sell parts via the Internet.
  14. bobofky
    bobofky Member
    107
    The main ECM operates from the 12v battery in the trunk. If the battery is not up to par the computer may cause weird things to happen.
