Battery jump/boost/replace?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bobz1x, Sep 22, 2011.
  1. Bobz1x
    Bobz1x New Member
    pomona, ca.
    what do carry in your car if the battery fails and there is no way to get jump?
  2. jdenenberg
    jdenenberg EE Professor
    3,912
    1,914
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have a portable jumper battery with a built-in air pump and trouble light. It is good insurance as long as you remember to keep it charged
    JeffD
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I carry a cell phone...
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    and my AAA card.
  5. Bobz1x
    Bobz1x New Member
    pomona, ca.
    thanks jdenenberb
    firepa63 & xpcman: "there is no way to get jump?"
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    Yes, you can get a jump. There is a "jump post" inside the engine fuse box. You must be "very, very careful" to be sure the polarity is correct or you could damage some very expensive electronics.
    Read your Owner's Manual about how to do this.
  7. Bobz1x
    Bobz1x New Member
    pomona, ca.
    well like jdenenberg carries a portable jumper battery with a built-in air pump and trouble light.
    is there a unit owners prefer for the prius?
  8. ETC(SS)
    6,856
    You can jump start a G3 with a 12-volt dewalt battery....IIRC.
    You're not "starting" the car, you're booting it up, therefore even the most diminutive "jump start" gizzywhopper that you can get at Wal-Mart will probably serve you just fine.
    They're cheap, and they have the advantage of having a light, veeeery wimpy compressor, and (sometimes) a USB charging port.
    Good Luck!
  9. Bobz1x
    Bobz1x New Member
    pomona, ca.
    gotcha thank you
  10. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I keep a 12V 7AH sealed battery in the car.
  11. Mendel Leisk
    40,287
    I picked up one of these a few years back, when I needed to periodically start a stored car with a dead battery:
    It would fit in the hatch area underfloor tray, but I'm reluctant to keep it there constantly: it's around 16 lb's. But good insurance if you need to park the car somewhere for an extended period, say at an airport.
