Battery Longevity
Discussion in 'Gen 2 Prius Main Forum' started by bredekamp, Mar 1, 2007.
  1. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    Hi all,
    Toyota claims that laboratory testing have shown the HV battery in the current model Prius (2003+) to last well in excess of 290 000km. I make a habit of keeping my cars a long time. What's the highest verifiable mileage obtained in a current model Prius with no significant battery degradation?
    Data from john1701a.com regarding an owner named Jesse, shows that the first generation Prius is certainly a tough die-hard car. What's the experience with the current model?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    There are quite a few well over 100k miles...I'm sure some over 150k. The only failures I'm aware of in the 2G prius were felt to be due to flawed batteries, not wearing out.
  3. tochatihu
    tochatihu Senior Member
    9,456
    3,654
    Kunming Yunnan China
    2001 Prius
    Andrew Grant has 240 k miles on a new model Prius taxi and still seems to like it OK.
    http://www.greentaxi.org/testimonials.php
    Might be fun to invite him here to discuss the entire Yellow cab Prius fleet.
  4. sebapisa
    sebapisa Junior Member
    I am sure everyone uses NiMH batteries for a lot of things and they DO wear out with the time. My Prius has only 350 miles so I can't tell,
    I'd be very interested to hear from someone with more than 100k miles about how is the battery doing and gas mileage cause I'm sure with the battery in bad shape the gas mileage will go down.
    Does anyone know how much would it be to put a new battery after the warranty expires?
  5. luckyboy
    luckyboy Member
    204
    29
    <div class='quotetop'>QUOTE(ByWire @ Mar 1 2007, 11:07 AM) [snapback]398483[/snapback]</div>
    Once the car has 150K+ miles, if you ever have to change the battery you could probably find one pretty cheap from a salvaged prius. The supply of totaled priuses with salvageable batteries should always surpass the number of older priuses needing new batteries. Plus toyota will pay you to return the old batteries.
  6. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Few, if any, devices manage their batteries as well as the Prius does. The car's computer goes to great lengths to prevent the battery from either being overcharged or excessively drained -- major causes of shortened battery life.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    You can get a used one for about $700 (ebay) now or a brand new one for $2,150 + $215 S&H.
    I am thinking of adding another pack to extend the stealth range. I've been in a pretty heavy traffic jam (rare) and stock battery is not enough. I hate it when it drives like a Civic hybrid (the engine comes on to move an inch). By adding another HV pack, I may be able to capture more energy in regenerative braking. Say, both packs will be able to capture 56 hp instead of 28 hp.
    Can someone with plugin conversion comment on it?
    Dennis
  8. brick
    brick Active Member
    1,083
    79
    Upstate NY
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Mar 1 2007, 01:44 PM) [snapback]398594[/snapback]</div>
    It's a topic for another thread, but I have wondered about that, too. I suspect it would be more complicated than running two battery packs in parallel because odds are slim that they would be identical in performance. Over the long haul (or maybe even not too long) you could end up with dissimilar states of charge. I could be wrong but I think this would involve interfacing with a second battery control module to handle the second pack.
  9. Tideland Prius
    16,401
    <div class='quotetop'>QUOTE(tochatihu @ Mar 1 2007, 08:02 AM) [snapback]398481[/snapback]</div>
    Actually, I believe it's much higher now. Also, Andrew doesn't own that taxi any more.
    i think it's at 500,000kms now.
  10. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    Im at 1796mi at counting, :lol: no problems yet!
  11. elisse
    elisse New Member
    2001 Prius
    I
    I was told that my battery would cost $3100 for the Prius 2001 I own and it has 170,000 miles. It has begun to degrade.
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Shop around and ye shall save 50% to 90%...
  13. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  14. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Nothing lasts forever.
    My 2004 Prius is at 181,000 miles and the original battery is still functional (but I'm sure that it is not as strong as it was new). The folks at Toyota are not stupid and they warrant the HV battery for 150,000 miles in many states (CA rules). If they expected more than a very small percentage to fail in that interval, they would not have agreed to the length of the warranty due to cost.
    As was noted earlier, the Prius battery is babied by the computer and Panasonic has improved it over the years (the 2004+ Prismatic cells are significantly more robust than the earlier designs) so that most of us will never see a battery failure. I probably will some day as I tend to drive cars into the ground before getting a new one.
    JeffD
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Yours is a Gen I battery. This discussion is about Gen II batteries, which should last longer than the Gen I batteries.
    Tom
