Battery Performance...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by NewbieOR, Apr 4, 2012.
  1. NewbieOR
    NewbieOR New Member
    Oregon
    What are people seeing with the mileage estimates on a fully-charged
    PIP battery?
    When I picked up my car from the dealer, I believe it showed 12.1. The numbers slowly increased over time and after one charge, it was 13.3.
    Since the 13.3 reading, I'm getting decreasing numbers every time I
    charge. I'm now seeing 12.4.
    In actual driving, I'm seeing slightly better results than the "posted"
    number because of regenerative braking. So, I'm not disappointed with
    the system... just curious what others are seeing.
    Thanks.
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Over the past 5 weeks, I've seen (almost in this order):
    13.3
    13.1
    12.8
    12.6
    12.4
    12.1
    11.9
    11.8
    11.6
    and today, a new low of 11.4
    My range is the same and my battery still charges to the same maximum as before. As many of us concluded here, it is most likely just calculating a "best estimate" based on your history and past driving patterns.
    My daily morning commute, which I make entirely on electric, is about 13.5 miles. I consistently make it to work with about 1.0-1.4 miles of EV range left, regardless of what my initial EV range says.
  3. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    If you ventilation is on, turn it off and you may get about 1 mile back. I am typically seeing about 11.8 at full charge- with the air off.
  4. NewbieOR
    NewbieOR New Member
    Oregon
    I see your posted MPG and I'm chasing it. I'm currently at an estimated
    80 MPG. I hope to make it to 90 before my first fill up!
  5. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    There are few people here that will do much better than that, I'm guessing. But I can't complain, better than the 18MPG I was getting before :D
    If you havent already done so, you should sign up on Fuelly.com
    I wouldnt worry too much about the battery. It is a little irritating to see the number drop fairly consistently, but I think its safe to say that there shouldnt be any issues this early in the game.
  6. NewbieOR
    NewbieOR New Member
    Oregon
    I only see 2 PIPs on fuelly.com with relatively low numbers; are other
    PIP numbers posted elsewhere?
  7. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Fuelly only shows participants who have 3 fill-ups or more. When no one had 3, it showed everyone. Now, to see everyone, you have to click this tiny link at the top that says "show all". Here's the page with everyone displayed:
    2012 Toyota Prius Plug-in MPG Reports | Fuelly
    2 people like this.
  8. planeflyer
    planeflyer Junior Member
    26
    Canby Oregon
    Hey, good to see another Oregonian on the chat. I've had my PIP since March 7 and with all this cool weather, I've been seeing consistent full charge readings of 11.4. My overall mileage is showing 74 mpg and the first tank of gas actual mileage was 71.3 vs. the readout of 73 mpg. Where did you take delivery?
  9. LenP
    LenP Member
    257
    69
    Morris County, NJ
    The PIP seems to estimate how far it thinks you can go on a charge, due to your driving pattern.My PIP is doing the same thing..Starting at 13.1 now around 11.5 I have a lot a small hills where I live and they eat up range. On flatter terrain you'll go a lot farther. It's a great car.
  10. LenP
    LenP Member
    257
    69
    Morris County, NJ
    Track, interesting that your getting 13.5 every day, and your PIP is still estimating down! I guess the reality is that the number that's showing isn't as important as how far you can travel in the real world.
  11. SCDrJ
    SCDrJ New Member
    120
    Orange County, CA
    I think the numbers are going to vary wildly, as we will all have different EV/HV usage. I only get 4-5 true EV miles per weekday out of 60, for example, but I CAN charge at work. If I were not able to do so it'd be HV almost the whole way home and much lower MPG. I also anticipate more EV miles on the weekend for short trips.
    Overall I am predicting low 60s MPG for me where the Gen III Prius I replaced was low 40s for the same. I have put both cars' Fuelly links in my sig so we can see a direct comparison of the PIP's advantage.
  12. TerryS
    TerryS New Member
    San Jose, CA
    Well, I feel a bit cheated. Brand new, my display showed 11.3. After two weeks I'm down to 10.1. The temperature has been fairly mild so I'm not using the climate control much....who knows.
  13. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Yes, I've noticed it too. I hoped it would go UP, instead of DOWN.
    2 Full charges per day.
    13.3
    13.1
    12.9
    12.7
    12.3
    12.3
    12.2
    12.2
    10.7
    12.1
    11.6
    12.1
    11.9
    10.0
    11.6
    11.5
    11.5
    11.3
    11.5
    11.4
    11.3
    10.1
    11.2
    11.1
    11.1
    11.0
    11.1
    11.1
    11.0
    I may need that portable Lithium Battery soon !!!
  14. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Another PiP thread that is not inspiring my purchase decision.
  15. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    Well, how about just went down 4 bars on fuel gauge, 410 miles on trip meter, hsi showing 110 mpg.
    If i stay off the freeway, i just might make that 1k tank.
  16. LenP
    LenP Member
    257
    69
    Morris County, NJ
    It's a fantastic car. I spoke with the dealer today and was told what we already figured out here. The number the car computes is derived from our driving pattern, not the state of the battery charge. I drive almost pure EV and in three weeks my gas tank is still 99.9% full and my MPG is still showing 999MPG.:)
  17. 9G-man
    1,273
    194
    Atlanta, GA
    OK, I'm inspired again. :) Seeing as how next Tuesday should be the big day, I need to be.
  18. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    I think you will like it. Your EV miles depends on your driving habits. Maybe the people who have 10 miles just floor it at stop-signs.
    I'm finding that. even in my 3rd week of driving, I am learning how to drive more efficiently.
    It is an awesome car!
    My number has been going up... :)
  19. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    That looks good, but don't forget Fuel Economy which has 'My MPG'. I tracked my fuel records there for most of the 2 1/2 yrs that we had our 2010. Lots of info on the whole site as well.
    radio
  20. stephens5.rich@gmail.com
    [email protected] New Member
    39
    Los Gatos, CA
    I got my car on 3/19. I commute 31 miles each way 3 days per week (cycle the other days) and am only able to partially charge from work for the way home (They don't have a real charging option yet - there working on it). I haven't had to fill up yet but I currently have almost 700 miles and am sitting at 105mpg with about 1/3 tank left. Unfotunately I don't do many short trips so only use full EV about 1/3 of the time. Once I fill up, I will post the numbers. Although there are always little things that I think could have been done, like the battery charging cable bag, hint, hint, I agree that this car is awesome! I expect to have to fill up by the end of next week so stay tuned.
