Battery
Discussion in 'Gen 2 Prius Technical Discussion' started by Locust43, Sep 7, 2006.
  1. Locust43
    Locust43 New Member
    33
    What is the 12 Volt battery for in my 2006 Prius? I thought everything just ran off the Hybrid battery.
  2. troe
    troe New Member
    83
    <div class='quotetop'>QUOTE(Locust43 @ Sep 7 2006, 12:45 AM) [snapback]315604[/snapback]</div>
    The lights, radio, nav, door locks, power windows, AC fan and other accessories are all 12 volt. It would pretty expensive to make those all run off of 270 volts.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    It's also necessary to start the car as the HV battery is normally disconnected to prevent harm and parasitic drainage when it's turned off.
  4. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    The 12V battery powers most (all?) of the electronics, including the computer. Most significantly, since the computer has to boot up before the car can start, you need the 12V battery to start the car.
    Jim
    EDIT: You guys (pcflorida and efusco) are just too fast for me! That's what I get for using a dialup connection.
  5. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    It's worth clarifying that as soon as the hybrid battery is online (in READY mode), all the 12V battery is doing is being trickle-charged from the converter; all 12V system power is coming from the converter, so ultimately the HV battery is providing all the power. This is much like a conventional car, where all the power comes from the alternator (although that does rely more on the battery for smoothing).
    But the 12V battery needs to be there to boot the system (because the HV battery is isolated for safety when the car is off) and it provides all the power when the car is in OFF, ACC and IG-ON modes (for central locking, alarm, radio, windows, ventilation, brakes, lights etc.) Only the electric motors and the A/C compressor run directly off the HV system.
    Interestingly, I have heard it suggested that all the lights in a Prius last longer than in a normal car, because the 12V system is so much better regulated than in a traditional car. Does anyone reckon this is true in practice?
  6. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(KMO @ Sep 7 2006, 05:44 AM) [snapback]315651[/snapback]</div>
    Right, I tend to think of the 12V battery like the CMOS battery on your motherboard.
  7. dolj
    dolj Senior Member
    8,112
    4,127
    Wellington, New Zealand
    Not sure why you needed to reply to a 16 year-old thread when the very next post answered the very same question to which you replied.
