BEEP-BEEP-BEEP
Discussion in 'Gen 2 Prius Accessories & Modifications' started by B Rad, Aug 26, 2006.
  1. B Rad
    B Rad New Member
    295
    I don't want to disable the back up beeper, but would sure love to lower the decibles a bit. If I could find and get to the actual beeber, maybe I could wrap something around it to muffel the sound a bit. Where is it and how do I get to it......??????
  2. walt
    walt New Member
    195
    Bel Air, MD, USA -=- Blair, Merlin, Merka
    <div class='quotetop'>QUOTE(B Rad @ Aug 26 2006, 11:22 AM) [snapback]309744[/snapback]</div>
    http://priuschat.com/index.php?autocom=art...owarticle&id=13
    may not quite answer your question, but may provide a different alternative.
    i believe the sound actually comes out of the center dash speaker.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    The OEM reverse beep comes from the amp and plays through the speakers, so no way to muffle it. Best to install a REAL beeper hooked to the reverse light and then disable the interior beeps. Download the PDF referenced in the URL above.
  4. B Rad
    B Rad New Member
    295
    <div class='quotetop'>QUOTE(Bill Merchant @ Aug 26 2006, 11:46 PM) [snapback]310019[/snapback]</div>
    Sounds like a good plan. Can anyone give me an idea as to the volume of the Preso Buzzer decribed in the above URL as compared to the stock back up BEEP. I want it just audible inside the car and as a warning to those close behind. Don't need to let my nieghbors no when I leave for work.
  5. Bill Merchant
    4,096
    85
    The one I got from Radio Shack is pretty obnoxious, but it can be heard outside the car, wheras the speaker beeps couldn't be. I toned it down recently my putting a square of sound-deadening material over it, so most of the sound is directed outside.
    You might look in automotive catalogs or on-line for backup beepers. I noticed a delivery truck the other day that had a chime. The idea is to warn pets and pedestrians when you are stealthing backward at them. No one said it had to be annoying.
  6. adgo82
    adgo82 New Member
    34
    <div class='quotetop'>QUOTE(Bill Merchant @ Aug 27 2006, 04:45 PM) [snapback]310265[/snapback]</div>
    When I was in Korea they had trucks that would actually play songs when they where on reverse. An all time favorite of mine was La Cucaracha.
  7. Bill Merchant
    4,096
    85
    I've seen "horns" that will play music or even act as a public address system. I think you could upload or record into it too. So you could record, "Hey! Watch out! I'm Backing up!" and trigger the recording with the backup light.
    Overkill.
  8. B Rad
    B Rad New Member
    295
    I now have a quiet back up beeper. followed this thread http://priuschat.com/index.php?autocom=art...owarticle&id=13 and put in the radio shack buzzer, only first I added some foam padding around the buzzer and some extra insulation to the little compartment behind the tail light. This makes a nice beep that can be heard both inside and outside the car without being to loud, and you can pad the buzzer to your own tast in noise level.
  9. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Bill Merchant @ Aug 27 2006, 04:08 PM) [snapback]310305[/snapback]</div>
    J.C. Whitney has several, including one that says (in either English or Spanish), "THIS CAR IS BACKING UP!"
  10. Lil Mo
    Lil Mo New Member
    171
    Now if you sing that to "La Cucaracha", you may be able to sell it for $$$
    :D
  11. Bill Merchant
    4,096
    85
    I'm backing up now! I'm backing up now! Don't you get behind my car!
    I'm backing up now! I'm backing up now! If I hit you, you'll go far!
    (sung to the tune...)
