Beep inaudible
Discussion in 'Gen 3 Prius Technical Discussion' started by jayqx, Jun 5, 2011.
  1. jayqx
    jayqx New Member
    Decatur GA
    I have a high pitch hearing loss and can't hear the beep at all. Is there any way to change the beep to a lower pitched tone or another sound? Any suggestions will be appreciated.
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Look for flashing lights and other signs on the dash board.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard! I too am losing some ranges but there is one thing I can hear only too well is the tone/beep.
    Your dealer maybe able to replace the speaker with something else. I don't anyone here has been able to locate it.
    51,994
    i also have a 60's rocknroll hearing loss. i try to fill up at 2 or 3 pips.
  5. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    You first need to track down and access the speaker(?) that the beep comes from. If you can find it you can add a pair of leads to its signal lines and run them to anything you want such as:
    * An auxillary speaker in the headrest where you can hear it.
    * A light on the dash where you can see it
    * The lead triggers a relay that engages a shaker so you can feel the beep.
