Best Android Phone setup?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TheNewGuy8, May 6, 2011.
  1. TheNewGuy8
    TheNewGuy8 New Member
    74
    So I'm getting a fully-loaded 2006 prius and I have an HTC Droid Incredible. Obviously I want to play music through my phone via the Aux jack (from my understanding the bluetooth on this model does not do music, just phone, right?).
    However, the aux jack and power are in the center armrest - right? Well that won't work b/c I won't have access to it for various selections.
    So what is the best set up here? I can always just put it in the center cup holder with the cords snaking out but that seems poor. Have people figured out slick dash setups or proclip setups with re-directed aux cords and power?
    I definitely want something that looks clean but allows me access to the phones controls.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Buy a small ipod, leave it in center console. a 8 gig nano is about $140 at Amazon. Or you could run wires...
  3. DarkStarPDX
    DarkStarPDX Junior Member
    26
    Hillsboro, Oregon, USA
    But then you have to own an iPod! Yuck! :rolleyes:
  4. TheNewGuy8
    74
    The problem is that, at least in the 06, theres no ipod integration. So if the ipod is in the center console I can't easily change music.
    So I'd have to buy an ipod AND an ipod integration unit.
    There's GOT to be an easier way...
    Has no one around here wanted a cell phone accessible while driving music?
    What about some sort of mounting towards the bottom of the center gap between seats?
  5. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I'm not sure I understand what you want - you're not happy with using an aux cable through the center console and resting your phone in the cupholder? That's what I do.
    Why not? The iPod doesn't have to be in the center console. As I said, an aux cord can sneak out the top of the center console and you can put your phone in the cupholder.
  6. opnsrcaddict
    opnsrcaddict New Member
    Michigan
    I've gone through many different setups for accessing and changing music through a few different cars. Like you, I find a phone the most convenient because I always have it with me and it's easiest to add music to on a whim. With an iPod left in the car, you would have to go out and retrieve it every time you wanted music. I'm way to lazy for that.
    If you want to keep the stock system, I'd recommend getting an aux extension cord and routing it to the dash, tucking it under whatever trim pieces you can.
    As for actually holding the phone, look up the Scosche DashDock Universal Dash Mount on Amazon. I can't post links yet, but it has a blue sticky gel that holds the phone. The mount itself sucks, but the part that holds the phone works incredibly well. The sticky back works much better than the vice type holders I've used before. I just took off the part that actually holds the phone and used double sided tape to secure it to the dash. The sticky dries out now and then, but a bit of saliva fixes that real quick.
    The best setup I've found is with an aftermarket head unit that supports the A2DP bluetooth protocol. I have an Alpine cda-105, and I can't imagine an easier way to get music to play from my phone. You can literally plop the phone on the dash and it will automatically launch a music player when the car starts and bluetooth connects. You can run wires any way you want, but nothing beats of everything starting automatically. The phone call integration is also just as seamless. If you want a clean looking connection, an aftermarket head unit is the way to go.
  7. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    It's too bad you have the JBL system otherwise i'd say ditch the factory headunit and god aftermarket stealth.... ;)
  8. TheNewGuy8
    74
    So with those headunits - do you lose the ability to use the buttons on the steering wheel? Or can you use the car system AND the aftermarket? When you install these extra headunits does it disconnect the car's system? Or can you use both at the same time?
  9. FreydNot
    FreydNot Member
    214
    37
    Seattle, WA USA
  10. opnsrcaddict
    Michigan
    I used a PAC SWI-JACK module to integrate the steering wheel controls with the new head unit. It works very well. By doing this you can totally circumvent the stock head unit. You may have to do the resister mod to retain your climate control system, see F8L's stealth install thread for more information on that.
    SWI-JACK:
    http://www.amazon.com/PAC-SWI-JACK-Steering-Designed-Blaupunkt/dp/B001EAQTBE
  11. TheNewGuy8
    74
    Ideally I'd REALLY like to just work with the built in system b/c I only plan to have the car for 2-3 years and I know all this modding lowers resale value.
    What I'd really like to find is a way to route USB power and aux through the dash out to the left corner and put on a left-mount proclip. Then I'll have audio and bluetooth and all the original controls.
  12. rictorg
    rictorg New Member
    Augusta, GA
    I've been thinking about going this route. How's the sound quality compared to plugging in via the phone's headphone jack? Can the phone connect to the RIM device and the car's bluetooth simultaneously?
  13. FreydNot
    FreydNot Member
    214
    37
    Seattle, WA USA
    I find the sound quality to be very comperable to hard wireing using the headphone jack on the phone.
    Yes, my phone automatically connects to the BlackBerry Gateway and also the Prius hands free at the same time. That is one of the things I really like about the BlackBerry Gateway; it doesn't try to be a Bluetooth speakerphone.
    Before I got the BlackBerry Gateway, I had one of these: Amazon.com: Kensington LiquidAUX Bluetooth Car Kit with Remote for Music Phones: Cell Phones & Accessories
    It constantly battled with the Prius hands free system.
