Best Consumption reset
Discussion in 'Gen 3 Prius Audio and Electronics' started by Sangye Menla, Nov 15, 2009.
  1. Sangye Menla
    Sangye Menla Junior Member
    Seattle
    I'm at 250 miles on a 2010 Prius, still trying to figure out a lot of the electronic display stuff and the Owner's Manual comes up short in places. In particular, I am confused about the Best Consumption display. It was working fine and I figured out how to set it, but now, whenever I check there, it only displays a couple of dashes - as if it's not computing it, or hiding the information somewhere. Can anyone help with this? :confused:
  2. Tideland Prius
    16,402
    Every time you reset Trip A or Trip B, it will record your best mpg so if you reset the best mpg, it'll probably read nothing or dashes (I'm just guessing since I've never resetted mine). So try driving around then reset Trip A or B and it should come up again.
    Btw, you might wanna fix your profile. The Prius I isn't for sale (fleet only) so if you bought a base model, you probably have a II.
  3. Sangye Menla
    Seattle
    I reset both Trip A and B, and have been driving around quite a bit (~60 miles) since doing so, but both Trip A and B "best consumptions" still both read dashes. Thanks for the tip on updating my profile.
  4. jim256
    jim256 Member
    317
    69
    Eastern NC
    I believe the Best Consumption displays after you have done a second reset of A or B. It's showing the best of previous trip readouts, not best of the current ones. p 197 & 198 in the manual.
