Best Tires For So. FL For Wear Without Milege loss
Discussion in 'Gen 2 Prius Technical Discussion' started by Walker1, Sep 7, 2007.
  1. Walker1
    Walker1 Empire
    911
    FL
    Hi All, I know there have been posts about tire replacement, but i'd like to know if someone down here in So. FL has worn out the factory tires and replaced them with some that will last a lot longer and not lose milege. It's almost always hot here and the roads do tend to eat soft tires faster. I have 22,000 miles on my 2006 and I might make 30K, but that would be pushing it.
    I am satisfied with what I have except for the wearing factor. I would appreciate all feedback.
    Thanks all.
  2. Walker1
    Walker1 Empire
    911
    FL
    As 104 people have read this post & gave no feedback does someone know where I can find previous tire posts on this site?
  3. Walker1
    Walker1 Empire
    911
    FL
  4. GKarschnick
    GKarschnick New Member
    50
    Melbourne, FL
    I replaced my Integrities with Goodyear Comfortreds, but then saw a 5 MPG hit. I returned them for a set of Goodyear Regatta 2's and have been happy. The MPG is the same as my Integrities and they are listed as a low rolling resistance tire.
  5. GKarschnick
    50
    Melbourne, FL
  6. Walker1
    Walker1 Empire
    911
    FL
    <div class='quotetop'>QUOTE(GKarschnick @ Sep 13 2007, 08:44 AM) [snapback]511852[/snapback]</div>
    They soung good but i have 2 questions. 1) What did each tire cost? 2) How many miles are the tires rated for? Thanks.
  7. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Just as a suggestion, you might try a site like TireRack to help you find something that fits your needs. Consumer Reports also does annual tire comparisons. There have been many tire threads here over the years, but I'll be charitable and say they're not necessarily objective.
  8. Walker1
    Walker1 Empire
    911
    FL
    <div class='quotetop'>QUOTE(hyo silver @ Sep 17 2007, 12:57 AM) [snapback]513540[/snapback]</div>
    Yes, But the people who drive Prius's are the ones who know if MPG is affected. Cosumer reports knows nothing about our cars except what MPG they average with stock tires. I want to get a set that will last perhaps 60,000 miles instead of around 30,000. From what I've read it seems our cars are very fussy about the "shoes" we put on them. Have you replaced yours yet?
    Sounds like a winner. What did they cost?
  9. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    <div class='quotetop'>QUOTE(Walker1 @ 2007 09 17 20:27) [snapback]514115[/snapback]</div>
    No, I haven't. But I'd place road noise and rolling resistance (MPG) below traction and braking. And, given our locations, what works for me isn't necessarily going to work for you. I need something that will handle heavy rain and the occasional wet snowfall. For me, I think the choice is between the HydroEdge and the TripleTread.
  10. JSH
    JSH Senior Member
    2,605
    140
    PDX
    <div class='quotetop'>QUOTE(Walker1 @ Sep 17 2007, 10:27 PM) [snapback]514115[/snapback]</div>
    I haven't replace the tires on the Prius but I have on my VW TDI. The TDI came with a Michelin Energy low rolling resistance tires that lasted about 40K miles and the car got 50 mpg highway. These tires had poor wet traction and snow traction.
    I replaced them with Falken Ziex 512 High Performance All-Season tires priced at $40 each from EdgeRacing.com I am on my 3rd set as they last about 35K miles. The last set cost me $256 for tires, shipping, mount / balance and new valve stems. The car still gets 50 mpg highway.
    I would rate them as follows:
    Dry Traction: Good
    Wet Traction: Excellent
    Snow Traction: Fair
    Noise: Good
    Wear: Excellent (For a performance tire)
    I personally don't buy tires that last more than about 40K miles because they don't have enough traction. Your tire is the only thing that connects your car to the road and to me this is not an area to try to save a few bucks. (My motorcycle tires only last 5K miles and cost $350 / set mounted)
  11. drifty1955
    drifty1955 New Member
    100
    Florida roads are really hard on tires because they used to mix seashells into the asphault. Extremely abrasive. There's still alot of those road surfaces around. Tires really wear out quick down here. I don't think I've ever gotten more than 35k out of a set without them getting scary since I've moved down here. I'm leaning towards the Goodyear Comfort Treads when I replace.
  12. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Replaced the OEM's with Goodyear Comfortreds from Tire Rack at 15,000 miles. Initially took a 2 MPG hit that went away as they broke in. I keep my PSI at 38/40.
    The Comfortreds are smoother, quieter and much better in the rain than the OEM's and look like new after 20,000 miles on them.
  13. Walker1
    Walker1 Empire
    911
    FL
    <div class='quotetop'>QUOTE(jhinton @ Sep 18 2007, 09:21 PM) [snapback]514585[/snapback]</div>
    I know about bike tires. My Harley only has 6800 miles on it & the back tire is more than 1/2 worn. I will gladly pay a little more to get tires for both the Prius & the Harley that will last a lot longer. Have you ever shopped Tire Kingdom?
  14. JSH
    JSH Senior Member
    2,605
    140
    PDX
    <div class='quotetop'>QUOTE(Walker1 @ Sep 19 2007, 08:13 AM) [snapback]514750[/snapback]</div>
    We obviously have different criteria for tires. I will gladly pay more for a tire that has more traction even if the tire life is shorter. I have not shopped Tire Kingdom. I have purchased from tirerack.com and edgeracing.com with positive results from both.
  15. Walker1
    Walker1 Empire
    911
    FL
    <div class='quotetop'>QUOTE(jhinton @ Sep 19 2007, 05:47 PM) [snapback]514982[/snapback]</div>
    Thanks for your feedback.
  16. partipilo
    partipilo Weirdo
    76
    West Palm Beach FL
    <div class='quotetop'>QUOTE(Walker1 @ Sep 7 2007, 12:06 AM) [snapback]508370[/snapback]</div>
    Hey, I'm in WPB too. My prius is 2 days old today... Where'd you get yours? If you got it from Earl Stewart, they give you free tires as long as you get your service done there (oil changes/rotations).
  17. wile-e
    wile-e Junior Member
    50
    I recently replaced my stock tires with the Bridgestone Potenza G-009 Performance tires. $70 a tire and they are speed rated with a 50K warranty. After a trip to Northern Cal and another to Tacoma from the Portland area. My mileage seems to be a little better and the grip in the rain has been phenomenal.
    In the Pacific Northwest having a good grip in the rain is essential for tires and drivers..... :)
    I chose these tires based on the Tire Rack comparisons and the fact that every low rolling resistance branded tire seemed to have stopping problems in wet and icy conditions. You don't want to drive SR14 with tires that slip in the rain! 1000 foot drop offs, lumber trucks, and rock walls can hurt.
    I remember the Florida roads, and the same types of problems occurred in Arizona. Go with an H speed rated tire and you won't have as much to worry about with the heat. Stay away from the cheaper soft tires they tend to get chewed up by the hot pavement. I would stay above the 8.0 rating for tread wear.
    I hope that this helps!
    PS Watch out for the gators and possums! They are hard on the tires! B)
  18. Walker1
    Walker1 Empire
    911
    FL
    Thanks for the tips. What exactly is Tire Rack? Is it a physical chain of stores or an online business? I have resided down here since 1990 & have had no run ins with gators or otherwise. (Good thing!).
    Thanks.
