Biodiesel Prius?
Discussion in 'Gen 2 Prius Technical Discussion' started by frayz, Apr 22, 2011.
  1. frayz
    frayz Junior Member
    33
    Mobile, Al
    Was riding behind one of these french fry machines last night. just wondering if anyones tried to convert a prius to biodiesel either with engine mods or a complete engine swap..
  2. richard schumacher
    7,664
    1,042
    United States
    No sane person would try: the Atkinson cycle gas engine fundamentally isn't suited to Diesel, no existing Diesel engine would fit mechanically, and Diesel doesn't fit the run-stop philosophy of the Prius design. Much better to put a Diesel into a pure series hybrid where it could run continuously.
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    What does that have to do with PriusChat? [​IMG]
    4 people like this.
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I am thinking a Bio-Gasoline Prius would be easier - BioButanol. Wondering if somebody could make a garage Butanol reactor, that took in SVO and put out Butanol?
  5. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    As pointed out previously, you can't (easily) convert a spark ignition engine to run diesel or bio-diesel.
    More compatible fuels are LPG, CNG, ethanol. More exotic fuels include wood gas.
  6. Politburo
    Politburo Active Member
    971
    208
    I see three logistical problems, assuming you're talking about using ABE:
    The ABE process is anaerobic
    You need to separate the ABE at the end (you could leave the ethanol, I guess)
    I'm not sure you can get from SVO to butanol using ABE as you need starch
  7. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Politburo,
    Thanks for that. One only need to remove the A from the ABE. Might as well leave the Ethanol in there. I think I am remembering they have processes to keep the E under 10 % of the BE produced in the ABE. Although, those might be licensed microbes for that.
