Black Bars in Consumption Screen
Discussion in 'Gen 2 Prius Technical Discussion' started by cheule, Sep 19, 2007.
  1. cheule
    cheule New Member
    39
    First off, I did a search for this topic, didn't find it. If it's been discussed I apologize, just point me in the direction of the thread, thanks!
    Often times if I drive for a while and the ICE doesn't turn on (i.e. all coasting or electric drive only) the MFD won't register a 100 MPG bar like it should. Instead, it'll show a black bar in the Consumption screen. Also, from what I can tell, the MPG for that segment isn't added into the average. I'm not sure on that point, but after watching it for a month now, I think so.
    Here is a picture of what I'm talking about, note that I was driving for all 30 minutes recorded on the Consumption screen. The black parts you see are when I was driving so efficiently that the ICE never turned on at all in that 5 minute period.
    Anyone have any idea if this is normal behavior? Is there something I can do differently to stop the MFD from getting confused?
  2. Spoid
    Spoid New Member
    286
    I've seen that once. I was coming down Mt. Charleston and coasted most of the time. That's the only time I've seen it.
  3. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I have a black bar every once in a while. I wondered if it was an anomaly or defect. It was a long distance drive, the car appeared to be at an optimum operating level (good fuel economy, fully charged battery).
  4. Arts137
    Arts137 New Member
    17
    It's SOP. If the ICE does not go on for the period, a blank-bar results. It happens in jammed rush hour traffic in my experience. It has been discussed before, but I could not find the thread either.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    Only in non metric countries. In a metric country it would mean 0L/100km so no confusion.
    I have seen this on another thread and the theory is that the original calculation is in metric converted to US measurements by software, there fore if the consumption is 0L/100km there is no consumption to report so a reading of 0mpg comes up.
    There have been at least 3 previous threads on this.
    http://priuschat.com/index.php?act=Search&...ite=missing+bar
  6. mxvet
    mxvet humble
    26
    davenport, ia
    I saw it yesterday for the first time.. stuck in traffic due to an accident... went about 1/2 hour with no ice creeping along..thought i'd get a great mpg reading once i was back up to speed. No such luck !
    i believe there must be a low end threshold of speed that you must hit to have it register.
  7. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    See it quite often. Especially in the mountains or in heavy traffic. The bar is left blank because it would have to display infinite mileage otherwise. Which would be ridiculous. So it trips the divide by zero catch in the software and calls for a blank. It's more meaningful when the display is l/100 km, as the blank is 0 l/100 km, which it is if you move and don't burn fuel. ;)
    I think it still uses the data in that 5 min interval in the overall mileage calculation though. If it was the only five minute interval (ie - reset just before it) then no, it would throw that calc. out temporarily and wait for more data.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(patsparks @ Sep 20 2007, 05:37 AM) [snapback]515171[/snapback]</div>
    Correct. With our miles/gallon calculation you get a divide by zero error if no fuel is used. Toyota chose to display infinite mileage as a black or empty bar.
    Tom
  9. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    So the metric prii more accurately display what is going on if you travel a distance and don't use any fuel (0L/100km).
    That leaves me with the question of what the metric prii display when fuel is used during a 5 minute interval but the car doesn't move. That should create a divide by 0 condition with the metric L/100km measurement. The non-metric Prii accurately display this as 0 mpg.
  10. cheule
    cheule New Member
    39
    Thanks for the replies, and thanks Patsparks for the proper search wording. I was thinking "black bars" never tried "missing bars."
    This divide by zero hypthesis sounds totally reasonable, because if I've used the ICE at all it doesn't happen. The part I'm less sure about, though, is if the average MPG is receiving no data for that 5 minute period.
    I suspect this divide by zero error is causing the average to stay unchange because the last few tanks my MFD average has been 3-5 MPG below my calculated. If I recall from other threads, it's usually the other way around (MFD usually slightly overcalculates MPG compared to a paper tally). I've had quite a few black bars this tank so I'll see how far over the 55.6MPG I get that the MFD is reporting.
  11. David Beale
    5,963
    1,985
    Edmonton Alberta
    <div class='quotetop'>QUOTE(Danny Hamilton @ Sep 20 2007, 09:16 AM) [snapback]515255[/snapback]</div>
    Pearl shows -.- l/100 km.
  12. patsparks
    10,664
    567
    When I fill up and the milage resets if I don't get going but the ICE starts the instant reading is 99.9L/100km so I would imagine if I sat still for long enough and the ICE had run in that 5 minute segment I would just get a full height bar, I'll have to try it now.
  13. SureValla
    SureValla Member
    590
    Shelton, CT
    is there anyway to quote "flip a switch" to make the american prius read in metric?
  14. Fitchdave
    Fitchdave Silver Squirell
    30
    South Shore Boston
    <div class='quotetop'>QUOTE(SureValla @ Sep 20 2007, 06:39 PM) [snapback]515486[/snapback]</div>
    I've had the black bar show when sitting in traffic without moving for more than 5 minutes, then black. If crawling along in traffic, no ICE, then full bar.
  15. bwilson4web
    15,933
    If you have 35 minutes, you can use this trick to fill your display with 100 MPG bars. First warm-up the car by driving 45+ mph for about 20 minutes and drive to a parking lot on a day without rain, wind and temperatures above 60F:
    1) stop car, leaving it in "N" and wait for current 5 min. bar to transfer to summary area
    2) slip car in "D" and gently achieve 6 mph to get one, 100 MPG bar
    3) slip car into "N" and wait 5 minutes
    4) when 100 MPG bar shows up in summary area, goto step 2.
    After 35 minutes, take a photo of full-bar, display and have a happy.
